Is this as would be expected? This was my first over-haul... new belts, bearings, grease....
Operation up to 1800 RPM is purdy darn quiet. Starting at 2000 RPM the top end begins to generate a bit of noise, on up to 4000 RPM it's very loud (louder than prior-to the overhaul). While I had belt-squeel and bad-bearing rattles before, the sound is of rotation (low-pitch whirling).
There is almost no vibration, so I suspect the sound to be from the veri-belt and pulleys.
