586,609 active members*
3,621 visitors online*
IndustryArena Forum > Community Club House > Ball screw question from a new guy!
    Mar 2009
    7
    I'm interested in getting into the whole CNC scene, and got some ideas/drawings down on paper. Id like to mill precision model aircraft wings, each being about 7' in length. Considering how long I need the length to be, I was thinking about using belts and metal timing pulleys on the X and Y axis- but ran into a problem:
    When using belts/pullys on the X and Y and a ball screw system on the Z, how does one ensure the same amount of movement per step on the Z, as well as the X and Y? Is there a formula or calculator somewhere, or can this be controlled via software? Do you know how other people who have overcome this problem?
    Thanks for the help!
    Mar 2004
    1806
    Ben,
    Depending on software, "most" will allow you to set the needed steps in each axis. Most do NOT require they be the same.
    Hope this helps.
    Art
    AKA Country Bubba (Older Than Dirt)
    Mar 2008
    3655
    Hi Ben. Welcome to the Zone!
    Some CNC info:
    http://www.cnczone.com/forums/showthread.php?t=76865.#3
    CR.
  1. Ball screw Question
    By rodzilla in forum Linear and Rotary Motion
    Last Post: 03-02-2007, 11:16 PM
  2. Z Axis Ball Screw Question
    By rcazwillis in forum Uncategorised MetalWorking Machines
    Last Post: 11-16-2005, 03:51 AM
  3. acme screw to ball screw question
    By Billw in forum DIY CNC Router Table Machines
    Last Post: 07-18-2005, 06:10 AM
  4. Ball Screw Mounting Question.
    By Willyb in forum Uncategorised MetalWorking Machines
    Last Post: 01-18-2005, 07:02 PM
  5. Ball Screw Question
    By jjwl89 in forum DIY CNC Router Table Machines
    Last Post: 07-20-2004, 01:12 PM
