586,685 active members*
2,293 visitors online*
IndustryArena Forum > CAM Software > Mastercam > Mastercam Startup Problems
Results 1 to 12 of 12
    Apr 2009
    Question Mastercam Startup Problems
    OK... so its my 4th attempt at installing Mastercam X3... i downloaded X3 and X3 MU1 both from mastercam.com... i have a licensed network through my school at Rensselaer Polytechnic Institute (RPI) and contrary to what the site says X3 will run on Windows Vista.. I know because my teachers and classmates all use X3 on Vista...
    so the problem is whenever i try to start up X3 I get the same error message:
    " NO SIM FOUND "
    Now I am connected to my network even though I'm off campus and I've already copied the nethasp from my school into the c://xcamx directory.. also i reinstalled the drivers for the SIM... and yet I still get the error message...
    ANYONE GOT ANY SUGGESTIONS???
    Jan 2007
    203
    Try following these directions!
    http://www.mastercam.com/Support/Tec...00_NetHASP.htm
    The "No Sim found" error points to the inabillity to read the network licens key!
    If you google it you will also find other solutions for that problem.
    All comments made are my opinion!
    Apr 2009
    haha i actually looked through there but gave it another shot... i reconfigured the nethasp.ini file and what-do-ya-know it worked!!! thanx!!!!!
    Jan 2007
    203
    Figured as much.
    You may want to add "RESOLVED" to your Title.
    Jan 2006
    Quote Originally Posted by Neceda View Post
    Can u send me that file to: [email protected]?
    Or can U tell me what did U modify?
    Thnx.
    Jan 2006
    33
    same problem
    I have the same problem can you send me the info on how to fix.
    Oct 2010
    who to fix "no SIM"
    would you please send me the way to fix it because I have the same problem you had.
    thank you
    Aug 2010
    18
    ***no sim found***
    can someone send me the fix too?
    Jan 2011
    129
    I have the same "no sim" problem. could you send more details on the ini reconfig. Thanks, Chuck
    Mar 2011
    I NEED SERIOUS HELP
    ok so im the only girl in my Machine Tech class im a first year student but I seem to be doing pretty well in here. My teacher is having me install the program Mastercam X3 to some of the computers in the lab. So I set them up however when I tried to open it I got the error message of NO SIM FOUND, Im pretty good with computers but no where near good enough to figure this out on my own. Please help anything would be great! thanks
    ~Sixela
    Jan 2011
    129
    Quote Originally Posted by sixela View Post
    ~Sixela
    You can't do the installation using "remote desktop"
    Feb 2013
    Basil Okoro
    I have the same problem and i don't know what to do about it. Please is there any solution to the problem?
    " NO SIM FOUND "
  1. Mastercam X startup error
    By Thinwater in forum Mastercam
    Last Post: 01-12-2009, 09:28 PM
  2. Any problems using mastercam?
    By kyo in forum Mini Lathe
    Last Post: 10-12-2008, 11:43 AM
  3. R2E4 Startup problems
    By jeep534 in forum Bridgeport / Hardinge Mills
    Last Post: 10-24-2006, 08:32 PM
  4. mastercam startup problems
    By sixthearl in forum Mastercam
    Last Post: 01-31-2006, 05:20 PM
