586,068 active members*
3,706 visitors online*
    Mach3 Lathe Thread
    Hi, we try to use both Mach3Version3.043.000.exe and Mach3Version3.042.020.exe to make M20*1.5 thread/60Degree, Materials is Aluminum Bar: D= 20MM,L=154MM
    G Code as follow:
    G40 G18 G80 G90 G95 G97 S334 M03
    G00 X0.525
    G00 Z0
    G00 X-0.1
    G76 X-1.5 Z-20 Q1 P1 J0.05 L45 H0.05 I0 C1.5 B0.0001 T0
    M5
    M30
    1: Picture 1: It is not 60Degress, not smooth, (Speed @190RPM)
    2: Picture 2: It is not better Speed at 160/220 rpm
    Any suggestion to make a good thread?
    Oct 2006
    47
    I hope you have already solved your problems with threading. If not, you should check this topic at machsupport forums. Lot's of good info!
    http://www.machsupport.com/forum/ind...ic,8314.0.html
    Good luck
    Frank
  1. Anybody thread milling on a Sherline mill with Mach3?
    By mpolcyn in forum Mach Software (ArtSoft software)
    Last Post: 06-13-2014, 02:41 PM
  2. Thread milling with Mach3?
    By Apples in forum Mach Mill
    Last Post: 05-02-2008, 06:17 PM
  3. Thread Mill in lathe
    By TOM R in forum G-Code Programing
    Last Post: 01-23-2008, 11:40 PM
  4. Cutting thread on CNC lathe by Mach3 ?
    By jimmychand in forum Mach Software (ArtSoft software)
    Last Post: 01-22-2008, 06:12 PM
  5. Looking for Mach3 Zdepth Thread
    By ramasule in forum DIY CNC Router Table Machines
    Last Post: 12-24-2007, 11:53 PM
