Originally Posted by
mdframe
I have 3 PowerMax II nema 23 bipolor stepper motors.
These motors are rated for 60 volts. I have caught snippets here and there that you should use linear power suppliers for steppers with 5 to 10 times the rated voltage to get the best performance.
Matt
Are you may be confusing motor rated voltage with the Powermax amplifier rated to go with these motors, some which are rated at 60vdc?
Your motor voltage is probabally going to be much lower, Pacific Scientific usually only specify current in their specs.
The Torque of a stepper will decreases with speed due to the inductance (resistance in ohms) change as speed increases.
This would normally decrease the current through the windings and decrease torque, so a couple of methods are used to offset this, one is to apply a high DC voltage with a series resistor which progressively controls the current as impedance increases.
The other method is to use the same higher voltage but chop the DC so that a mean level of current is fed through the winding as impedance increases with speed. You will need to look up the current rating per winding of your particular motor in order to implement either method. I have most of the P.S. specs. if you need it looked up.
Al
Albert E.
