586,115 active members*
3,341 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > Mini Lathe > HELP! DeskCNC X-axis doesn't respond.
    Apr 2009
    I am setting up a Sherline CNC lathe from IMService with DeskCNC controller. The z-axis is working perfectly, but the x-axis does not respond at all. When I checked the voltage on the controller, there is no voltage between Xstep or Xdir to ground. I temporarily connected the Y axis and it worked perfectly too. The voltage on the Z and Y axis pins on the controller are the same, but I don't recall what it is. I don't know if it matters, but when I connect the controller to the servo driver, xstp stays at 5v and doesn't change ever. Any help is more than appreciated. I find is hard to believe the board is bad.
    270
    Post to the IMService private user support forum. We can help you troubleshoot setup problems at that location.
    Fred Smith - IMService
    http://www.imsrv.com
    Apr 2009
    Thanks Fred. I have my request in to be setup for the forum, I'll post as soon as that's complete.
  1. Grinding Cam profiles on a DeskCNC 4 axis mill
    By Paraprop in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 08-15-2015, 06:16 AM
  2. test plug rs232 port not respond
    By joseponzo in forum Fadal
    Last Post: 10-16-2007, 07:23 PM
  3. Sporadic Failure to Respond
    By IQChallenged in forum Machines running Mach Software
    Last Post: 06-28-2007, 03:48 AM
  4. Fadal 904-1 does not respond to inputs
    By tigerinnovation in forum Fadal
    Last Post: 01-23-2007, 12:26 AM
  5. Does xylotex ever respond to email?
    By JohnG in forum Xylotex
    Last Post: 11-04-2006, 10:31 PM
