Hello everybody ,
I need some information about following step by step motors :
1. MAE HY200 2226 0470 ACM8
2. MAE HY200 2220 0100 ARM8
3. Sanyo Denki Step Sin 103-770-3251
I have tried on Google , but with no significants results.
Hello everybody ,
You can find info on MAE steppers here;
http://www.ametektip.com/index.php?o...article&id=169
Timothy
I found this at http://sanyo-denki-online.com/
Our simplified stock numbering system identifies each motor instantly. As an example, here is our Nema Size 34, 720 oz/in., 6 amp, single shaft, bi-polar motor. Here's how it works.
Example for stock # 346-720-SB
The first two digits indicate the Nema or Metric frame size.
The third digit(s) indicates the motor's amperage.
720= Ounce inches of holding torque rounded off.
S or D =Single Shaft or D=Double Shaft
U or B=Bi-polar four wire or U=Uni-polar six wire
Cheers
Baxy
moving this reply to new thread
Found info on Step-Syn 103-770. Hope it's helpful.
http://www.rta-deutschland.de/pdf/103-770.pdf
