586,111 active members*
3,097 visitors online*
IndustryArena Forum > MetalWorking Machines > HURCO > Hurco ATC arm Problem
    Apr 2009
    We currently have a Hurco VM1, it seems like there is some type of limiter on the rotation of the arm. The arm doesn't rotate far enough the pick up the tool, but once it alarms out I can push the arm the last 1/4" to make everything line up. The Hurco service tech that I talked to doesn't seem to have any idea of what is going on. Any help would be appreciated.
    Jake
    Oct 2007
    19
    HURCO VM1 for ATC unit still using air system, have 2 air cylinder for 0-60 degres and or 180 degres, so i think your machine have problem on 60 degres rotates, sound like your linear gear on atc unit for 60 degres run out, because you can still push for make line up with tool, meaning the linear gear end move but your arm can't end to 60 degres and the alarm show on your machine. This problem happen to my machine last time ago, so i dismantle ATC unit and set-up the position of linear gear (for 60 degres ) and my machine back normal. ( sorry my bad english )
    Jun 2008
    1104
    Have you got enough oil in the little pot on the side of the toolchanger? 32-37 hydraulic oil (Tellus or similar). Is the toolchange height correct? Will it complete a toolchange without tools in it? Is your air pressure sufficient (100psi)?
    It takes 20 mins to adjust the 60 degree switch on these things.
    Apr 2009
    VM1 Tool Arm
    Quote Originally Posted by mpi View Post
    Jake
    Jake Please call Hurco Tech support 800 638-1849 and I can help
    Nov 2006
    382
    Call Steve, I just got through this about 6 months ago with him. You will be back up and running soon.
    Jetski (alias Tooling and Engineering Czar)
    "I may not have the keys to success.. but I have learned to pick the locks"
  1. hurco km3 problem
    By junaid.wahid in forum HURCO
    Last Post: 11-17-2008, 09:26 AM
  2. Hurco Spindle Problem...
    By XXcammasterXX in forum HURCO
    Last Post: 07-07-2008, 03:12 PM
  3. Hurco BMC 30 problem with spindle
    By electromech in forum HURCO
    Last Post: 04-19-2008, 05:43 PM
  4. Hurco Security Problem
    By racer6645 in forum DNC Problems and Solutions
    Last Post: 12-18-2006, 04:56 AM
  5. HURCO ATC problem
    By jawwad in forum DNC Problems and Solutions
    Last Post: 11-09-2006, 08:26 PM
