Originally Posted by
JeLC
One thing I forgot to mention was that I originally started out running Linux and EMC2 on this system. With Linux/EMC2, there is a latency test for checking out how fast the processor responds to the control program when it needs to generate a pulse. The system I'm using measured somewhat high, but, according to EMC2 documentation, within specs to run a machine. Mach3's printer port test did not show any problems with the speed of the PC. And I'm guessing that the Mach3 printer port test is the equivalent of the Linux latency test. (and yes, I do know the latency problem didn't just go away by installing XP and Mach3. Matter of fact, since I've gone back to a Microsoft product, it is probably gotten worse).
Pulse generation problems would normally show up in multiple axis, not just one. But if the emc latency test showed marginal, odd's are that MACH3 won't do as well.
Any chance the coupler set screw is slipping?
Phil, Still too many interests, too many projects, and not enough time!!!!!!!!
Vist my websites - http://pminmo.com & http://millpcbs.com
