Hey Dave,
You know, it's a funny thing about that.. I really dont understand how this could have happened...
As I mentioned I was using the machine daily, the nut was never too tight, never run without lubrication.. It's very strange indeed that the screw stripped the way it did. I saw no evidence this was happening. The machine didnt lead up to this with a few inaccurate jobs or anything. Almost like it happened during the last job run. The screw was stripped down at about center of the length and only an inch and a half or so of the screw was stripped. I use two vices in an effort to prevent wearing one spot down but that really only benefits the X leadscrew since both vices center the work on the table. One thing for sure, the screw stripped right where it does the most work, it's just a little funny that it didnt show syptoms before failing. I mean, you should see this screw... the threads are ground down to the shaft!
I would think this kind of damage would have certainly been problematic for a week or so before stripping to the point that the screw turns but the table didnt move.
Know what Im saying?
Anyway, the nut seems to be in perfect condition. Yeah, go figure...
As I removed the leadscrew from it and got close to the end of the screw where the threads were pristine, the nut held snug with no play. A visual inspection also confirms the nut if in very good condition.
Dave, you bring up a very important point.
Why did the screw strip and the nut doesn't sustain any damage?
One last thing... I own the DSLS 3000 Taig. Are the leadscrews the same for all the Taig mill models?
Thanks everyone
Regards,
Mike
