587,047 active members*
2,519 visitors online*
IndustryArena Forum > CAM Software > Dolphin CAD/CAM > output a D after the G41 or G42...
    Dec 2008
    15
    I'm wondering if Partmaster Pro outputs G41, G42 and a D for tool number?
    a friend mentioned that looks like this Dolphin CAM does not output a D after the G41 or G42...
    can anyone please clarify me on this ?
    thanks
    cs
    May 2007
    428
    Shape that is actually pretty simple. We would just make a minor post change for you. It's done directly inside of the PP.
    Dolphin CAD/CAM Support
    Dec 2008
    15
    thanks,
    I would assume that small change on the PP is also possible on
    Partmaster Standard ,
    right?
    thanks
    May 2007
    428
    Yes it would be the same. Keep in mind, Pro is much more customizeable and provides quite a bit more.
  1. Programmed RS-232 output
    By ghyman in forum G-Code Programing
    Last Post: 01-24-2020, 09:40 AM
  2. please help- cnc spindlefrequency output
    By Scoma in forum CNC Machine Related Electronics
    Last Post: 06-18-2008, 05:25 PM
  3. 11M output module
    By hobiedude in forum Fanuc
    Last Post: 01-08-2008, 06:05 PM
  4. G-Zero by Rapid Output!!!!!
    By tobyaxis in forum Uncategorised CAM Discussion
    Last Post: 02-05-2007, 05:16 AM
  5. torodial output seems odd
    By trubleshtr in forum CNC Machine Related Electronics
    Last Post: 04-22-2005, 02:42 AM
