586,069 active members*
3,247 visitors online*
Results 1 to 6 of 6
    May 2008
    23
    EZ Trak Internal addressing error
    One of our programmers is getting an internal addressing error that stops the program.
    This seems like it could be a corrupt memory issue. Anyone have any ideas?
    Zeke
    May 2009
    Internal address error
    is the internal address error a #4 , I am having a similar problem it might have to do with a post processer requriement for useing G code .txt programs files . I am haveing a problem running a .txt file that was created in master cam
    May 2008
    23
    Zeke
    I don't remember what the error # was the 1st time, but the next time it was #10. We are using the post processor for SmartCAM that we've been using for 10+ years. If this has happened before I am unaware of it.
    May 2009
    I am trying to use a editor called preditor , for a program that was created on master cam. It seems that the mill is not recognizing the text file for some reason I inceryed the numbers for each line obtion , I also used the ACSII sysmbol before the % and it gets the same error #4. I am not that familure with useing CNC's in the G code mode I always just used the easy track program system that it comes with
    Mar 2009
    4
    Quote Originally Posted by Tigrita View Post
    Tigrita.. suena medio latino tu Nick..
    Can you send me email ...??
    [email protected]
    I work with Smartcam, Mastercam9, MastercamX2 for Bridgeport.
    Feb 2005
    154
    x
  1. EZ-Trak start-up error
    By jfm in forum Bridgeport / Hardinge Mills
    Last Post: 10-08-2009, 03:53 PM
  2. EZ Trak Error
    By dustindavenport in forum Bridgeport / Hardinge Mills
    Last Post: 12-25-2008, 02:15 PM
  3. ez-trak system error
    By Tru Cut Machine in forum Bridgeport / Hardinge Mills
    Last Post: 08-28-2006, 03:33 AM
  4. Internal Addressing Error
    By BobL in forum Bridgeport / Hardinge Mills
    Last Post: 06-06-2005, 11:11 PM
  5. Internal addressing error
    By BobL in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 05-26-2005, 05:55 PM
