586,096 active members*
3,459 visitors online*
IndustryArena Forum > Mechanical Engineering > Linear and Rotary Motion > Grease fittings for Hiwin 20mm blocks
    Dec 2008
    445
    Having a hell of a time finding compatible fittings for the Hiwin 20mm series of guides and rails. According to the spec sheet, and confirmed by measurements, the thread seems to be a metric 6mm X .75mm. What is available is a 6mm X 1mm fitting, at least as far as I've found. Either one of the blocks I ordered was missing a fitting, or I misplaced it, but either way I need to pick up some new ones, and straight ones at that instead of the 45 degree ones that were supplied. Anyone have any advice where to find these things?
    Aug 2007
    558
    Eric ('Widgitmaster' Eric... ) was looking for the same size IIRC, he was able to get them somewhere near him. You might have a search and see if he mentions where he got them. If you get real stuck, I have some - let me know & I can send 'em over.
    Best regards,
    Jason
    Edit - Widgitmaster found them at an auto parts store...
    http://www.cnczone.com/forums/showpo...&postcount=424
  1. What size THK/Hiwin rails and blocks?
    By Zumba in forum Linear and Rotary Motion
    Last Post: 08-18-2021, 05:05 AM
  2. Lube fittings
    By dblais in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 05-01-2008, 07:04 AM
  3. need hiwin cad files for old ag series rail and blocks
    By eloid in forum DIY CNC Router Table Machines
    Last Post: 03-11-2008, 02:36 AM
  4. hiwin guide blocks and rails
    By eloid in forum Linear and Rotary Motion
    Last Post: 12-10-2007, 12:46 PM
  5. Bijur Fittings
    By arsenix in forum Bridgeport / Hardinge Mills
    Last Post: 10-13-2005, 01:36 AM
