586,745 active members*
6,955 visitors online*
Results 1 to 16 of 16
    Sep 2004
    67
    help with boards
    Ok please bar with me, I know how to build things using wood/metal and so on, but electronics is a bit new to me. I've been to http://webpages.charter.net/pminmo/cncelectronics.htm , and he shows schematics of controlers(interface) and motor drives. I seen boards that are complete all in one, guess the motor drives are on the main board. Now what advantage is it to have an interface board with motor drive boards as to one board that does it all? Also, please once again forgive my ignorance but what are the differances between bipolar boards and unipolar boards? I am almost done building my cnc and am looking at the controler end of things. I presently have 3 stepper motors "sanyo denki 3.5vdc, 1.5a, 1.8deg/step type 103g7701848" I want to get a set of schematics for pminmo and I am not sure which one. I want it to be a 4 axis unit, because in the future I plan on building my own 4th axis. Does anyone have this schematics in eagle format? Also the complete parts list with a photo of completed boards to kinda guide us newbies thru part placement? Any help would get me going in the right direction. One last thing...THANKS pminmo!! Its not often we get ppl like you giving out free info for the better of the communite! This also goes out to all you that have done the same thing! I WILL contribute in the same way in the near furture
    1695
    If you're new to electronics, then you should try to pick the simplest circuit possible.
    You definitely want one of the "Chopper" drives. Otherwise you won't get much performance out of your motors.
    Your choice of drives depend on your motors. If they have 4 wires then your only choice is a bipolar drive. If they have 5, 6 or 8 then you can use either.
    Bipolar cost more, but can give you 40% more torque with the same motor. The motor you're using seems to be about the same size as mine, (which is rather weak) so you probably want a bipolar drive.
    The most cost effective bipolar design I'm aware of, is the a3977 board on Phil's site. But you will need to have the board done professionally, because the chip is so small you won't be able to do it at home.
    So that narrows your choice down.
    Jun 2003
    3312
    mocnc,
    Ask yourself what you are trying to accomplish, do you want to become familiar with electronics, or taking the satifaction of DIY. If not then buy a board like a xylotex or hobbycnc. The few bucks you save doing your own, probably isn't worth the hassle.
    Hobbycnc or Xylotex all in one boards (xylotex does have a single axis driver) are not modular in nature. If you decide you need a stronger stepper on one axis than the all in one can provide, you have to do some improvising. Essentially when the driver and the computer interface are on different modules, you have some fleability. For example you could use my 4 axis board with 2 axis of unipolar drivers, a 3rd of a bipolar driver, and a fourth a servo driver (if the servo driver emulates a stepper driver)
    Or you could build two axis and use a Gecko Stepper driver on one.
    There is one all in one board on my website, that is tachus42's 3 axis board. And there is a companion chopper board.
    Several of the boards have documents that include a part placement layout such as:
    http://webpages.charter.net/pminmo/osunidata.pdf
    In general a bipolar stepper can be about 40% stonger than a unipolar.
    What eagle files do you need?
    Phil
    Phil, Still too many interests, too many projects, and not enough time!!!!!!!!
    Vist my websites - http://pminmo.com & http://millpcbs.com
    Sep 2004
    67
    thanks,I kinda got an idea now. But I seen boards on Hobby cnc and other places that can be for a diy. Is there a board that someone can recommend that a diy can build. I thought phil's boards were for diy, guess I was wrong. I am looking to try and build from scratch myself. I know if may be a foolish thing to do, but I would love to learn how to build a board (both interface/motor drive or the one board does it all system). Does anyone out there have the schamtics or is this just a dream of a diy'r ? Also you said my motors are rather weak, how can I figure the strength in them? do I need bigger ones to drive my 1/20 drive screw, thats has the x axis-40" and y axis-"15 and the z axis-3"
    Sep 2004
    67
    wow that was fast phil lol I just typed my first responce and then there was yours lol , I guess what I am looking for is a way to run 4 axis. I now liking the bipolar cause of the 40% more torque and with my weak stepper motors that could be a blessing. I want to try and build it myself, not engineer the whole thing but build it from scratch. So I guess what I am asking is which one? Which interface do I get the schematics for and which motor drive boards? For the motor drives I would love to have one of each bipolar drive, unipolar driver and a servo driver. The last 2 are for future use only if my new design calls for it. I have the eagle light and I can't seem to do much with the size limitations of it. Does anyone know where I can get an older version that is complete? But then again if I have the schematics with the actual size the should be I can etch them myself
    Jun 2003
    3312
    Precisly what my website is for, those who want to DIY. Bipolar, use 3 L297-298 boards with the four axis interface board. All of the boards on my site were done in the Eagle light version. You would be surprised how much you can get in that small area, especially when using both sides and surface mounted parts.
    The eagle files are zipped here for the L297-8:
    http://webpages.charter.net/pminmo/L297-8.zip
    4 axis interface:
    http://webpages.charter.net/pminmo/4axisbob.zip
    Phil
    Sep 2004
    67
    Hey thanks Phil,
    Are they both single sided? for double sided? and is there a parts list for this boards with an actual picture to show what these boards should look like when they are done lol. I guess for a diy its nice to see the parts and where they go with no guessing. I also from cnczone got a pictural on how to make my own boards, does anyone of other methods? Has anyone made g-codes for these boards or any other boards? Is it worth it? Or is the old way the best? Will this work with my 6 wire step motors now? Also how do I determine which wire of my stepper motors go where? I have white, orange, blue, yellow, red, black. I know where the red and black go what about the other 4?
    Jun 2003
    3312
    both are single sided etched. Both have links to copper for toner transfer and parts layouts on my site. The interface board has a document to support it.
    Phil
    Sep 2004
    67
    Thanks once again phil, please bare with me, I think I got the board layout for the l297-8, I hope. Could you post the board layout for the copper for toner transfer and parts layouts for both? I hope I am not being a pest, I just want to make sure I am getting the right things. Also the actual sizes of the boards, what are they? Is the l297-8 8.5 inches by 11 inches? What is the 4th axis interface board? Last but not least, I tried looking for the auto route in eagle light and I couldn't find it. Does it have it in the eagle light? I wanted to run and make the copper layout so I could try and fabricate the boards. Oops forgot one more thing, have you ever or do you know of anyone who has theses boards written out in g-code for cnc/milling? Is that something way to imposible to do? If it has been done where could I get the g-code to cut these boards out of copper instead of using toner method.
    Jun 2003
    3312
    mocnc,
    You really don't need the eagle files: To make the pcb from my website:
    http://webpages.charter.net/pminmo/L297_8copper.pdf is the copper for toner transfer for the l297-8.
    To load the pcb use the layout from my website:
    http://webpages.charter.net/pminmo/L297_8board.pdf
    This is a little more tricky, the components you need by value are on the schematic on my website:
    http://webpages.charter.net/pminmo/L297_8schematic.pdf
    http://webpages.charter.net/pminmo/L297-8.htm
    You will need three of those boards for a three axis machine.
    The physical size of the board is 3.9 x 2.1 inches.
    Oct 2003
    593
    Quote Originally Posted by mocnc
    If you have access to the eagle files you can have gcode for milling, generated using the appropriate ULP script.
    Regards Terry.....
    Jan 2004
    71
    Here are two proven and very reliable designs. The pcb is professionally produced.
    http://www.embeddedtronics.com/microstep.html
    http://www.embeddedtronics.com/microsteppld.html
    Both will work fine, the pld version is faster but you will need a very fast PC to make use of it.
    The design is based on the National Semiconductor LMD18245 3amp 55volt full bridge motor driver. This is a very rugged chip capable of 6amp surges and has 12amp burst rating.
    Kin
    Robotics, CNC, and Controllers
    Jun 2003
    3312
    Yes they are both very nice looking designs. The intention of this board is to be easy and cheap. Unfortnuately the LMD18245 is $20 for one axis, but it's a great looking chip otherwise.
    Phil
    1695
    I just made a lmd18245 board driven with an avr. They're very easy to use. The code only took about an hour to write. But in Canada, the lmd cost $20 each. That's works out to at least $45 per axis, which is a bit steep.
    Athough they are only good for 2.5 amp at 35v, I think the allegro a3977 is more reasonable at about $10cad per axis. It's a standalone chip...no mcu is required. Just be sure to get it in the bigger package since the tssop version is far too small for home made pcb's.
    I will build one up as soon as I get my milling machine going.
    Feb 2005
    more help with boards
    Im reading about the different boards but have trouble comparing them.
    Would someone please compare the Camtronics http://www.seanet.com/~dmauch/
    with Hobbycnc? http://www.hobbycnc.com/driverboards/4aupc/4aupc.htm
    I 'm not asking anyone to bash one company or another, just tell me what I'm getting for my money. There is a huge difference in price so it makes me wonder if they are completely different products. Hobbycnc needs more assembly but I think both are DIY.
    I just want to drive a small plasma cutter.
    Thanks in advance
    1695
    Your link don't point to any specific board. But if you're comparing hobbycnc to gecko's in general, then:
    Both are good products. If your motors are unipolar and need less than 3 amp and you can solder the components onto the board, then hobbycnc is an economical choice.
    If they're bipolar and need more amps, and you want something pre-assembled, then the geckos are for you.
  1. Open Source Boards Available, Stepper Drivers and Break Out Boards
    By pminmo in forum Open Source Controller Boards
    Last Post: 06-23-2018, 01:46 AM
  2. Controlling Stepper motor driver boards
    By scarr in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 01-28-2006, 03:17 PM
  3. How do the controller boards etc work?
    By Hack in forum CNC Machine Related Electronics
    Last Post: 12-13-2004, 09:37 PM
  4. question about 2 X 2axis boards
    By Stevie in forum CNC Machine Related Electronics
    Last Post: 03-15-2004, 01:39 AM
  5. Wiring Diag for 3 Xylotex Boards
    By Mr.Chips in forum Xylotex
    Last Post: 02-02-2004, 07:08 AM
