586,108 active members*
3,073 visitors online*
IndustryArena Forum > CNC Electronics > CNC Machine Related Electronics > DZB200B inverter and 2.2kw hs spindel
    May 2009
    8
    I'm new to this international cnczone site.
    I decided to address my problem here since the dutch cnczone-members can't help me out.
    I bought a 1phase 220v Fuling DZB200B inverter along with a highspeed 3ph spindel. the motorplate on the spindel indicates:
    Φ 80*215 220v 2.2KW
    8A 400HZ 24.000 RPM
    it's a watercooled 80mm china-made spindel (...).
    at the inverter I entered the following menu entries:
    full reset (before I did this it was running just fine! stupid me...)
    F1-01 rated power of motor (2.200 w)
    F1-02 rated frequency of motor (400Hz)
    F1-03 rated speed of motor (24000 rpm)
    F1-04 rated voltage of motor (220v)
    F1-05 rated current of motor (8A)
    so far so good, but I have to fil out some more stuff and I don't understand all off that. it's the Φ 80*215 part I don't understand but has something to do with resistance I guess... (edit: it's the spindels diameter and length hahaha. found out just 2 min's ago!)
    still leaves me with the question how to determine the following:
    F1-06 motor stator resistance (Ohm)
    F1-07 motor rotor inductance (Ohm)
    F1-08 motor stator/rotor inductance (mH)
    F1-09 mutual inductance of motor stator/rotor (mH)
    F1-10 no load current (A)
    at this moment the motor spins, but makes a strange noise and isn't running smoothly. it also gives error code E0004 and E0006: current related errors. probably because I did'n adjust the F1-06 > F1-10. makes sense, right?
    any help is very much appreciated and for those would like to give it a try: the manual of the inverter can be found at the above link.
    thanks in advance and grtz from Holland.
    (yep, the queen is still alive... :wave
    roger;
    I regret that I can't help you with your problem, but perhaps you can help me with mine.
    I purchased a complete Vortech Router that has a Fuling DZB100B inverter in it that has accidently shorted its control Chip. (an aluminum chip got inside the inverter during cutting and was blown by its fan in between the ribbon cables connector pins)
    Where did you purchase your inverter from? and do they perhaps carry parts? I'm looking for replacment control board or chip for this model.
    I have had no luck finding anyone in the USA that can help me thus far. So any info you can provide will be greatly appreciated.
    May 2009
    8
    chip
    I sent them an email some time ago and they were very helpfull.
    Try http://www.fullingmotor.com/jsp/indexshow.do
    Anyway, these -or any electronic- parts are not dificult to find.
    Electronics go international.
    Find the partnumber and keep in mind that Google is your best friend...
    good luck
  1. best router spindel
    By Ed Williams in forum FAQ of DIY CNC Machine Building
    Last Post: 10-19-2014, 03:56 AM
  2. Spindel speed PWM controller
    By choelzen in forum CNC Machine Related Electronics
    Last Post: 07-28-2010, 06:07 PM
  3. mazak spindel alarm f46c
    By jaimeeduardo in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 09-10-2008, 01:45 AM
  4. Haas spindel Deriver, Regen problem
    By tayfunk in forum Haas Mills
    Last Post: 09-01-2008, 03:08 PM
  5. Quicker 2 spindel
    By satneo in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 08-18-2007, 01:05 AM
