586,075 active members*
4,029 visitors online*
Results 1 to 3 of 3
    Dec 2008
    Monochrome Bitmap
    Hello, I am attempting to scan a bracket then import it into Torchmate Cad to prepare it for a tool path. The problem that I am having none of my scanning software gives me the option to save the file as a monochrome bitmap. Therefore when I import the file into Torchmate cad I must do it as a regular bitmap and the scantools within the cad software stop me there. Any thoughts on what program to use or anybody have experience with this? Thanks.
    May 2008
    39
    r u selecting image and then go to mode then select monochrome . after that i go to the scan tools and use the center line trace
    hope that helps
    bakerj99
    Quote Originally Posted by bakerj99 View Post
    hope that helps
    bakerj99
    This is correct, you can convert the image to a monochrome bitmap in the actual CAD software by following the above instructions.
    -Mike
    Mike @ Torchmate.com | www.Torchmate.com
    Toll Free : (866) 571-1066 M-F 7:30am-4pm PST
  1. 3d relief from bitmap
    By walter in forum DIY CNC Router Table Machines
    Last Post: 01-02-2013, 02:16 PM
  2. Background bitmap?
    By THend in forum Mastercam
    Last Post: 05-31-2008, 10:33 PM
  3. Bitmap to .EPS
    By bengalsfan in forum Printing, Scanners, Vinyl cutting and Plotters
    Last Post: 05-12-2008, 04:55 PM
  4. Bitmap trace
    By tdnp in forum Vectric
    Last Post: 02-20-2008, 11:11 PM
  5. monochrome crt hard to read
    By bluej_x in forum Daewoo/Doosan
    Last Post: 01-31-2008, 05:54 AM
