586,052 active members*
4,157 visitors online*
IndustryArena Forum > Mechanical Engineering > Linear and Rotary Motion > NEMA 23 & 34 Bolt pattern & end frame size in. measurements
Results 1 to 6 of 6
    Feb 2006
    1260
    Hope these drawings will help someone else. I've had to convert these a couple times myself.
    posted in .jpg and .dwg formats.
    Drawings are for motor case referance only. Shaft size & length may vary from motor to motor.
    Recomend these measurments be checked across the face of the actual motor being used.
    Attached Files Attached Files
    If it works.....Don't fix it!
    Most (all?) Nema 23 stepprs have a .25" shaft, not .375". Usually, if they have a .375" shaft, they are larger 60mm motors, and not Nema 23's.
    Apr 2005
    1778
    Ger,
    I think that some of the higher torque Nema 23 steppers that Keiling sells are 0.375" shafts.
    Alan
    Feb 2006
    1260
    The drawing was taken from a 570 oz Nema 23 that does in fact have a 3/8" shaft. Good that you pointed it out though Gerry, I'd hate for someone to do machine work based on the shaft & then be wrong. I have edited the first post accordingly.
    Quote Originally Posted by acondit View Post
    Ger,
    Alan
    Yes, but they are not Nema 23, they are 60mm, which are larger. I checked that before I posted. I didn't check the hole pattern, which may be the same, but the motor is 3mm bigger than a Nema23.
    Feb 2006
    1260
    Gerry,
    The 570 oz in motor I am using is also 60 MM across the flat sides of the case. It was sold to me as a NEMA 21 by someone other than Keling. I did look up a Keling 282 Oz in motor, case size listed 56.4 mm (NEMA 21) & the end bell bolt pattern, center hub & bolt hole size are the same.
    So aparently they are calling the higher torque 60 mm case motors NEMA 23 merely because the end mount is the same.
  1. Circle With Bolt hole Pattern
    By JJsFab in forum Torchmate
    Last Post: 09-01-2013, 06:07 PM
  2. Bolt hole pattern for Fanuc 18i
    By J.D.R in forum MetalWork Discussion
    Last Post: 01-31-2009, 11:33 PM
  3. programming bolt hole pattern
    By jrogus in forum CNC Machining Centers
    Last Post: 05-23-2008, 07:23 PM
  4. Bolt hole pattern with only a drill press
    By sanddrag in forum MetalWork Discussion
    Last Post: 05-04-2006, 07:41 PM
  5. 200oz in Motor Bolt Pattern
    By jhwatts in forum Hobbycnc (Products)
    Last Post: 10-13-2005, 03:40 PM
