586,114 active members*
3,256 visitors online*
Results 1 to 2 of 2
    Aug 2022
    Axis alignment
    Hello everybody.
    My question might soun little bit odd; but I'll try anyway.
    We have 1kw fiber laser cutting machine and we have problem with Y1 and Y2 axis. They are not aligned.
    When we cut square, diagonals are not the same, so it actualy becomes a romb.
    It's not a problem when we cut smaller parts, but bigger the part, bigger the error.
    So my question is could I solve the problem thru servo motor, or do I have to move one axis phisically.
    [URL]https://postimg.cc/G9RGx52G[URL]
    15362
    Re: Axis alignment
    Quote Originally Posted by tslc View Post
    Hello everybody.
    The axis needs to be squared mechanically; by unbolting and squaring to the table, you should not do this with the servo motors as this will add stress in the axis and gantry frame
    Mactec54
  1. Axis Alignment
    By blkexp98 in forum Epoxy Granite
    Last Post: 01-29-2017, 11:50 PM
  2. alignment of Z axis
    By Andriy77 in forum Haas Mills
    Last Post: 12-22-2016, 01:06 PM
  3. Alignment of X axis
    By grinder_gary in forum Open Source CNC Machine Designs
    Last Post: 01-10-2016, 12:22 AM
  4. Axis Alignment
    By WB-1 in forum DIY CNC Router Table Machines
    Last Post: 04-12-2012, 07:35 AM
  5. x-axis alignment
    By FLUTE HEAD in forum Vertical Mill, Lathe Project Log
    Last Post: 07-10-2005, 03:05 PM
