586,119 active members*
3,518 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > Fanuc 18i controller 926 FSSB alarm
    May 2007
    58
    We have been dealing with an issue on a machine I was wanting to ask you guys about. It is a 926 FSSB alarm, and the drive will have a "L" fault on it. I have changed the axis card, servo drive, servo motors, and wiring, swapted the fiber optic cables, and the issue will always stay with the drive, we have found that if you are to leave the electrical panels open then this fault will not occur. I have cleaned the cabinet cooler, and it will still fault, it will just take longer.
    Do you have any thoughts, or any questions?
    It's not what you cut...It's what you don't cut.
    Apr 2009
    108
    "L" alarm
    The L can indicate a defective fiber optic cable between the drive displaying the L and the next one in line. If this is the case the next drive should be displaying a U. Is this the case?
    Page 644 of GEFanuc manual 63005en shows how to isolate the problem to a particular component.
  1. FSSB 926 Alarm
    By Factory Guy in forum Fanuc
    Last Post: 03-19-2018, 04:26 AM
  2. ATC Alarm on Fanuc Controller
    By bikebasher in forum Fanuc
    Last Post: 01-29-2013, 06:28 AM
  3. Alarm 926 FSSB
    By wanchai101 in forum Fanuc
    Last Post: 01-10-2012, 09:44 AM
  4. 5136 FSSB alarm on fanuc Oi mate
    By leor in forum Fanuc
    Last Post: 09-02-2010, 03:45 PM
  5. FANUC 926 FSSB ALARM
    By sting_dot in forum Fanuc
    Last Post: 12-05-2007, 06:47 PM
