Hi I am new to the forum here
We have purchased a new machine FRAL400 a milling machine, that we have problem with the angle head..
Control we use is simens840D
and we use Mastercam X3
I have an X-axis 22000MM on the y-axis 5000MM
We have a problem with our angle head, angle head has a C axis that rotates
360 degrees, when we work in the 0 degrees stays the milling head vertical down,Then we can use this
program to mill the contour
N10 LOAD_TABR
N20 T="390125FRES"
N30 L06
N40 G17 G54 G64 G90
N50 Z1700
N50 TOOL_HOLDER(0,0)
N60 TOROT
N70 G54
N80 F5000
N90 S500 M03
N100 G0 Z1925
N110 G0 Y60.5 X-80.208
N120 G0 Z1720
N130 G1 Z1700
N140 G1 X-42.708
N150 G1 X372.5
N160 G1 Y-60.5
N170 G1 X-42.708
N180 G1 X-80.208
N190 G0 Z1925
N200 M5
N210 ROT
N220 M0
but when we turn our head 45 degrees, we must replace the x axis with the y axis
so then we must create new programs to the next angle
though the contour is the same
then we have to program like this
N230 TOOL_HOLDER(45,0)
N240 TOROT
N250 G54
N260 F1000
N270 S500 M03
N280 G0 Z1925
N290 G0 X60.5 Y-80.208
N300 S500 M03
N310 G0 Z1720
N320 G1 Z1700
N330 G1 Y-42.708
N340 G1 Y372.5
N350 G1 X-60.5
N360 G1 Y-42.708
N370 G1 Y-80.208
N380 G0 Z1925
N390 G0 Y-200
N400 ROT
N410 M5
but when we post out, the mastercam X3 using the same contour on all axes
like this
N10 LOAD_TABR
N20 T="390125FRES"
N30 L06
N40 G17 G54 G64 G90
N50 Z1700
N60 TOROT
N70 G54
N80 F5000
N90 S500 M03
N100 G0 Z1925
N110 G0 X60.5 Y-80.208
N120 G0 Z1720
N130 G1 Z1700
N140 G1 Y-42.708
N150 G1 Y372.5
N160 G1 X-60.5
N170 G1 Y-42.708
N180 G1 Y-80.208
N190 G0 Z1925
N200 M5
N210 ROT
N220 M0
N240 TOROT
N250 G54
N260 F5000
N270 S500 M03
N280 G0 Z1925
N300 G0 Z1720
N310 G1 Z1700
N320 G1 Y-42.708
N330 G1 Y372.5
N340 G1 X-60.5
N350 G1 Y-42.708
N360 G1 Y-80.208
N370 G0 Z1925
N380 M5
N390 ROT
N400 M0
N410 M2
CONTOUR
GEARBOX
Does anyone have experience with an angle head,
or been in the same situation that can help me with this ?
Thanks for all posts
