586,100 active members*
3,215 visitors online*
IndustryArena Forum > CNC Electronics > Xylotex > 4-axis unipolar kit
Results 1 to 19 of 19
    Jun 2004
    445
    4-axis unipolar kit
    Hi everyone,
    I've been looking at various boards lately for a small CNC mill and came across the 4-axis unipolar kit from Xylotex. This board seems ideal for me, as the kit is relatively cheap (good when you're a student without a money tree...). I should be able to get it assembled successfully, even with my limited knowledge of circuit board soldering...
    I have a few questions about this board though and its operation (assuming I can get one together):
    - If I wanted to run stepper motors rated at 4.5V and 2.5A/phase, what kind of power supply would I need to run it? Would I need seperate supplies for the board and the motors?
    - How is the current to the motors set and what is Vref?
    - Does the board have inputs and outputs for things like limit switches and coolant control?
    - Is it generally reliable and relatively simple to setup?
    I'm sorry for all these questions, but i have to learn somewhere...
    Warren
    35538
    First, it's just recently been released, and I haven't heard of anyone that has used one yet. But his other drivers are very high quality and very polpular.
    Power Supply - Just one needed, preferably 24V to 34V, about 6a minimum.
    You set the current by adjusting a pot to put out a certain voltage. That voltage is VREF. You'll need a meter to set it up.
    It looks like if you add some optional resistors, you're all set for limits. The board is set up for these, but not sure if they are included. Coolant might require a relay, which would not be included.
    This is just info I got from checking the website, but should be accurate. If you email Jeff from Xylotex, he'll answer all your questions. He's a great guy to deal with.
    HobbyCNC sells a driver that is basically the same as the Xylotex, at http://www.hobbycnc.com. A lot of people are very pleased with that one.
    Jun 2004
    445
    Thanks for the reply, Gerry.
    There's one thing that I'm still not sure of. I had a look on the Xylotex site and found a manual for this board. In this manual it says that the current to the motor is 'Vref/0.33' and that Vref can't exceed 1V. This all makes sense, because that explains the maximum current per phase being 3A. What I don't quite understand, is what the voltage to the motor will be. If the motor is only rated at 4.5V, the power supply is giving 34V and the Vref is set at say 0.8V (to give roughly 2.4A for the motor), then where is this 4.5V (approximately) coming from to drive the motor?
    Regards,
    Warren
    35538
    Steppers can and should be driven at much higher than the rated voltage. Steppers drivers only regulate the current. By using higher voltages, it allows the current to flow faster through the motor, which let's the motor spin faster.
    Jun 2004
    445
    Thanks again, I didn't realise that the motors could be driven at much higher voltages. Just as a matter of interest though, what exactly is the point of giving a voltage rating to the motor, if it doesn't really restrict it in any way? Does it have anything do do with its resistance by any chance?
    Regards
    Warren
    35538
    The voltage is the currrent rating times the resistance of the coils.
    Jun 2004
    445
    Hello again, and thanks for the replies - they really helped.
    Can anyone tell me exactly what is needed in order for limit switches to be used. Also, what kind of switch is normally used for limit switches?
    Warren
    Apr 2003
    540
    The switches use one of the output pins from your parallel DB25. If your driver board has terminials available that gives you access to the pins, it's fairly easy. The Xylotex site has some simple layout schematics for wiring your switches in either parallel or series configerations. You'll need resistors to pull the circuit low and then tell your software your setup so if recognizes when the circuit goes high (or visa versa), so it will stop (if a limit) or reference (if a homeing switch). Or, both if your software is capable.
    As far as switches, just some small microswitches will work fine. The kind with a small arm that bumps the switch. Wire in normally closed (NC) so that when a switch opens or a wire breaks, your circuit will make note of the open circuit and stop things.
    Do a search for breakout boards... they make things much easier and will protect your computer and provide the necessary resistors onthe board.
    Take a look here for info too...
    http://www.campbelldesigns.com/breakout_board_plus.htm
    and
    http://www.pmdx.com/
    -marc
    35538
    Marc, I think he's talking about the Unipolar board, which has provisions for the pull up resistors built in. They may not be included in the kit, but the space is on the board for them. So you don't really need a breakout board with the unipolar board. The schematics on the website (last time I looked) were for the bipolar drives.
    Sep 2003
    66
    itsme,
    I have just built this board. It was very easy to build and the instructions are straight forward. if you look at the bottom right hand corner you'll see a set of screw position wire lugs, it is set up for an "E" Stop, 3 home switches and a limit switch (You can Parralell as many as you need). The pull-up resistors are included in the kit.
    Sep 2003
    66
    The only thing I did different was to use wire where the LED was so that I could mount it as an Idiot light after I put it in a case. The second LED is an Idiot light to let me know that I have turned on my power supply.
    Attached Thumbnails Attached Thumbnails Controller Front.JPG   Controller Back.JPG   Controller Inside.JPG
    Sep 2003
    66
    I also took advantage of the boards feature to mount external enable switches for each axis. I don't know if I'll ever need them, but what the heck....It's cool.
    Hope This Helps,
    George
    Jun 2004
    445
    Thanks for those pictures, George. I ordered a 4 axis kit last night, so now I'm just waiting for the post. Can I assemble it with 'normal' electrical solder from the local hardware shop?
    I'd also like to know what everyone uses for the case to enclose their boards. Is it easiest to bend one out of some aluminium sheet, or use a container that is already available? George, is that fan a 5V fan that runs off the board's supply?
    The enable switches sound like a good idea. I'm guessing that these could prevent back EMF from damaging the board when (if) the machine is being used by hand??? If my guess is correct, then I think I might just do the same when the time comes.
    Lastly, on the back of your case, I see that you've connected the stepper outputs to some sort of plug. Are these just standard sockets that are available from most electronics places? They also seem like a good idea...
    Warren
    Sep 2003
    66
    itsme,
    1: Watch out on the solder, if you get it from a hardware store, make sure it's electrical solder. I jnow this sounds stupid, but they do carry solder for plumming which dosen't have a flux core and is different in compisition (Tin percentage mainly).
    2. For the case, I got this one on clearence at radio shack for $7.00, it was normally $12.00. so either way it won't set you back to much. The enclosure comes with a plastic and a metal bottom (or top depending on how you mount it) and had plastic lugs to mount a board. I took the metal bottom, cut it to size to fit the lugs and then mounted my Xylotex board to it using regular computer stand-offs.
    3. I haven't got a clue about the back-EMF, but the axis switches are handy.
    4. I used regular DB-9 conectors for my Controller and Cables. you'll end up with a couple extra pins but they work fine. I mounted all of the axis plugs vertical and the one horizontal plug is for my Home, Limit and E-Stop switch. I also custom made my cables with the DB-9 conectors on one end and the plugs that fits my Powermax II stepper motors on the other end.
    As an after thought, I would probably have made a Junction Box mounted to the actual machine as an "In-between" conection. If I had done this I could have ran the Limit/Home switch lines on the extra pins that were available on the DB-9 conectors (Also keeping Axis integity), Plus if you ever moved the machine, all you would have to do is un-plug the connectors at the junction box and at the computer and be able to move both without any wires getting in the way.
    Hope This Helps,
    George
    Apr 2004
    10
    DB-9 Conectors
    Hawkeye,
    What gauge wire can you use with your DB-9 Connectors? Are all DB-9 connectors rated for the same current?
    Thanks,
    Brickman
    Sep 2003
    66
    brickman,
    I haven't got a clue. I used some heavy duty LAN wire. it had 4 sets of shielded pairs and was solid wired. I'm sure there is someone here that knows though.
    George
    Apr 2003
    Solid wire is not especially a good choice for wiring up stepper motors. After a number of back and forth bending motions, it can break. The unipolar driver chip has internal diodes that will withstand over 100V, so you may not suffer the "blow-up" problems that the bipolar chip faces (the high voltage create by disconnecting the motor while running, goes through these diodes), but things wont work right if one of the condutors breaks.
    Jeff
    Sep 2003
    66
    That depends on if you are using a moving gantry or moving table machine. On a moving gantry, I agree. If you are building a moving table type machine, the wires shouldn't be moving on any of the axis.
    George
    35538
    Your router still moves side to side and up and down, doesn't it?
  1. HobbyCNC Unipolar Chopper Driver Kit!
    By HobbyCNC in forum News Announcements
    Last Post: 11-10-2009, 03:40 AM
  2. Is there an all in one Z axis kit?
    By CoffeeRich in forum Benchtop Machines
    Last Post: 06-13-2005, 03:01 AM
  3. 3 axis unipolar motor driver board
    By serkanozfe in forum Stepper Motors / Drives
    Last Post: 02-15-2005, 08:28 AM
  4. CNC Retrofit - Kit verses turn on and go
    By MetDetect in forum Uncategorised MetalWorking Machines
    Last Post: 07-13-2004, 04:06 AM
  5. 4th axis plans or kit
    By seansear in forum DIY CNC Router Table Machines
    Last Post: 04-01-2004, 06:52 PM
