586,075 active members*
3,714 visitors online*
Results 1 to 7 of 7
    Jul 2005
    302
    digital calipers - coolant-proof
    I think that everybody who uses coolant has the same problem,
    Still using cheap chine made ones ... very cheap, OK but tired about - few days and ... take a new one, sometimes even after five minutes you need a new.
    What exact digital calipers are coolant proof ?
    Or is it impossible?
    Thats because professionals using "oldies"
    Regards,
    Herbert
    Dec 2007
    362
    Look for calipers that are rated IP67. These will cost a lot more than the cheap ones you're probably using.
    Regards
    Geoff
    Jul 2005
    302
    Quote Originally Posted by tumutbound View Post
    Great thanks,
    Im ordering right now ... IP67 WATER PROOF DIGITAL VERNIER CALIPER 6" (150MM) D02
    will buy different,
    Regards,
    Herbert
    Feb 2008
    123
    Here are the ones that I use. Excellent set, they have been completely submerged in coolant and still trucking along after 4 years.
    Coolant-Proof Calipers
    You might be able to find them cheaper if you look around, but the price isnt too bad for what you are getting.
    Jul 2005
    302
    Danke!
    Now I have four coolant proof calipers - hopefully in next week ;-)
    Also Mitutoyo already bought - got for EUR 45.99 included shipping - not bad?
    Cheers,
    Herbert
    Aug 2007
    64
    As most of world need cheap ones, so The Chinese supply very cheap products. But some factory in China also make good quality products.
    You may choose IP 54, they are much cheaper. if you don't work under the water.
    http://www.roktools.com
    Dec 2008
    3109
    Quote Originally Posted by Herbertkabi View Post
    Go for the 8" / 200mm, a couple of dollars more, you won't regret the decision
    I find the 6" useless at the best of times
  1. Coolant Proof Paint
    By HackMax in forum Benchtop Machines
    Last Post: 03-15-2009, 11:51 AM
  2. Why digital calipers are better than the old dial (rack & pinion) calipers.
    By widgitmaster in forum Calibration / Measurement
    Last Post: 12-14-2008, 02:12 PM
  3. Digital Calipers for DRO'ing
    By SPEEDRE in forum Benchtop Machines
    Last Post: 02-07-2008, 06:18 PM
  4. Calibrate digital calipers
    By wowjimi in forum Calibration / Measurement
    Last Post: 12-30-2007, 10:41 PM
  5. digital calipers
    By skmetal7 in forum CNC Machine Related Electronics
    Last Post: 01-09-2007, 03:13 AM
