I want to be able to activate the coil of a relay with a photoelectric switch.
The switch is 24VDC, 100ma load. The relay is also 24VDC, 1.5VA (1W) consumption.
Am I correct in calculating that the relay has a draw of .04 amps and that the sensor will be able to drive this relay? Anything else I should be aware of?
