586,075 active members*
3,958 visitors online*
    May 2009
    Brother TC-227
    Hello all ! We're a small grinding shop that's getting our first taste of CNC machining and need some help with getting this machine going. We have the manuals and read thru them but don't really know where to start with this controller. The controller is a Brother CNC-520 , would anyone be willing to make a small video showing us the basics on getting started and send it to us via email or on a disc ? I know I'm asking for a lot , but sorry.
    Jul 2012
    11
    Brother TC-227
    The control is basically the same as a Fanuc, is anyone in your shop familiar with g-codes? Ours is a CNC 720 control but I imagine it is about the same. When you turn it on it will be in manual mode, jog the axes a little bit and hit the M.Z.RT button. now you are good to go, push the memory button, then the edit button, put in a new number for a new program and press enter, now you enter your g-code program. To run it press the memory button put in your program number, press enter, and then the green cycle start.
    After reading the manual you should understand that each tool has an offset which is set by you. they are pretty easy to set just move the tool to where you want zero to be, press the data set button and you will have the option to set the tool data or the working zero position, for tool data just select the desired offset number and there should be an auto setting option or you enter the absolute position into this register if no auto setting is available. For the working zero position you need to remember to call out the desired work zero at the beginning of each program but these registers are set by moving the tool to the desired x/y zero and either using the auto setting or entering the absolute positions.
    Hope this help! feel free to shoot me any other more specific questions
  1. Post for a Brother HS 70A
    By ewest in forum Esprit
    Last Post: 06-03-2019, 06:48 PM
  2. brother cnc 100
    By wratey in forum Uncategorised MetalWorking Machines
    Last Post: 10-06-2011, 11:05 AM
  3. Best for a Brother
    By 64dodge in forum Post Processors for MC
    Last Post: 05-10-2010, 11:02 PM
  4. Mastercam w/ Brother TC-2SA
    By lwilliams70 in forum Mastercam
    Last Post: 11-26-2007, 10:38 PM
  5. Brother Wire Edm
    By JINX222 in forum Waterjet General Topics
    Last Post: 01-28-2007, 10:46 AM
