I can't find a real datasheet for these motors.
Looks like the current setting is to high for series connection.
It would be better to use the half-coil connection and keep the 1.5Amp current setting, this will also increase the torque at higher speeds .
Using slow decay should reduce the motor heat a bit, the current ripple is lower and this reduces the losses in the motor.
Hope this helps,
Luc.
