586,112 active members*
3,089 visitors online*
IndustryArena Forum > MetalWorking Machines > OKK > OKK Pallet Check M-Codes
Results 1 to 7 of 7
    May 2009
    Smile OKK Pallet Check M-Codes
    Hi there!
    Looking for M-codes to verify pallets.
    A complete list of M codes for a OPKK MHC 600 would be super!!:withstupi
    Sep 2007
    122
    Better late than never...
    Did you try M61 and M62? Did you ever get a HMC book? I have a hard copy
    Nov 2007
    352
    Check Keep relay K22.5 equal to 1
    machine internal macro for pallet now active
    #1014=pallet 1------1 active o ouside
    #1015=pallet 2------1 active 0 outside
    Just right a macro before the program starts to check for the right one
    Can supply theem if needed
    Sep 2007
    122
    Keppers - thanks
    Thanks for the info. I can write this. It will help if our operators have the wrong pallet inside to start the cycle. Now the machine faults and the operator has to manually M code the pallet around.
    Thanks again.
    Jan 2013
    Quote Originally Posted by lshingleton View Post
    Can you post the macro needed to check the pallet?
    Nov 2007
    352
    O0001(MAIN )
    N10G200
    N20M98P0003(TOOL LIFE CHECK)
    M3S100
    N30M60
    N40IF[#1014GE1]GOTO100
    N50IF[#1015GE1]GOTO200
    N100(SUB PROGRAMS FOR PALLET 1)
    IF[#545EQ1]GOTO120 (Skip Pallet)
    N101M98P1101(SPOTFACE LOCK HOLE)
    N102M98P1102(DRILL LOCK HOLE)
    N103M98P1103(TAP LOCK HOLE)
    N120M99
    N200(SUB PROGRAMS FOR PALLET 2)
    IF[#546EQ1]GOTO220 (Skip pallet)
    N201M98P1201(SPOTFACE LOCK HOLE)
    N202M98P1202(DRILL LOCK HOLE)
    N203M98P1203(TAP LOCK HOLE)
    N206M98P1206(REAM EAR HOLES)
    N207M98P1207(DRILL - P - HOLES)
    N220M99
    M30
    Hope this gets you started
    Feb 2006
    37
    Re: OKK Pallet Check M-Codes
    NEED MANUALS FOR OKK MCH 600 , PLS HELP, REPLY TO [email protected]
  1. G codes and M codes for Mazak Quick Turn T-2
    By sauli in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 05-23-2011, 05:22 PM
  2. G codes M codes Mach3
    By eaglezsoar in forum Mach Software (ArtSoft software)
    Last Post: 02-04-2011, 12:38 AM
  3. Need full list of G CODES AND M CODES FOR FANUC 21I
    By SonnyTees.com in forum G-Code Programing
    Last Post: 02-23-2010, 05:27 PM
  4. M-codes and G-codes 4 Matsuura ES-1000V
    By maximusek in forum G-Code Programing
    Last Post: 11-27-2007, 01:41 PM
  5. correct pallet check
    By kmuller in forum Uncategorised MetalWorking Machines
    Last Post: 01-14-2004, 10:54 PM
