586,069 active members*
3,286 visitors online*
Page 1 of 2 12
Results 1 to 20 of 36
    Jan 2004
    231
    CNC laser table -- support for part
    I have a table I'm building that is going to cut sheet metal. It doesnt work yet, but it will use a 100 watt CO2 laser. (Please resist the temptation to post that 100 watters dont cut sheet metal -- they do).
    My question is about the platform/support that will hold the sheet metal.
    The original top on my CNC table was a 1/2 thick plate of aluminum. I bolted down 24 disc shaped neodymium magnets on this plate with a 4-40 socket head bolts. The idea behind these things is that they'll supply some magnetic force on the sheet metal to hold the sheet in place. The main thing I like about the system is that it is very level. This is important because the "sweet spot" of the beam waist is rather small, and changes in the Z-height of the metal will could result in cases where the beam will not pierce the metal.
    The set up as it is now works fine in that they hold the sheet metal quite nicely. The bolt head projects about 1/8th of an inch above the magnet but because its made of steel it transmits enough magnetic force up the post to adhere the sheet metal.
    The question I got is if this system will work. One thing I'm wondering is if the beam hitting the aluminum plate will put off undersireable fumes. The other question I have is if there should be more distance between the part and the support underneath. The gap between the sheet metal and the aluminum is around 3/8ths of an inch. I think it'd also be better if I had a grate underneath the part. That would definitely make for better ventilation -- I could put a vacuum system below the part to pull off fumes. Comments are welcome.
    This is the table:
    http://nilno.com/laser_dir/mag_table_003.jpg
    These are examples of the magnets:
    http://nilno.com/laser_dir/mag_table_004.jpg
    This is a part held on the table.
    http://nilno.com/laser_dir/mag_table_005.jpg
    owen
    Mar 2004
    16
    I can't help you on this but would appreciate if you can provide some info on the laser cutting part of your project
    Jul 2004
    28
    Owen,
    <<(Please resist the temptation to post that 100 watters dont cut sheet metal -- they do). >>
    Actually, they don't....
    There are 4 kinds of Co2 laser.
    1) Continous wave (100w laser of this kind, delivers 100w maximum)
    2) Gated pulse (100w laser of this kind, delivers 100w maximum)
    3) Superpulse (100w laser of this kind, delivers 100w X 2.5 times)
    4) Hyperpulse (100w laser of this kind, delivers 100w X 2.5 times)
    G-100 is a Superpulse laser and it has 250w Peak effective power.
    Now, about your table... It will be better if gap between the sheet metal and the aluminum is more than 3/8ths of an inch. If this gap is small, the reflected heat will bend the stainless steel sheet.
    Now, about your calculations...
    (At 1.6mm, if I have a 3x beam expander I get 4.8 mm, which will be 103
    micron using a 1.5 inch focal length)
    (equation: diameter = .013 * M^2 * (fl/D) where M^2 is equal to 1, and
    D is diameter of incoming beam.)
    Where did you found 1.6mm?
    Here is a table for G-100.
    Distance From Laser (mm) vs Beam Diameter (mm)
    0 mm distance = 1.9 mm beam diameter
    250 mm distance = 2.9 mm beam diameter
    500 mm distance = 4.7 mm beam diameter
    750 mm distance = 6.7 mm beam diameter
    1000 mm distance = 8.7 mm beam diameter
    1500 mm distance = 12.9 mm beam diameter
    2000 mm distance = 17.2 mm beam diameter
    In my case, the focal lens from the laser dinstace is 500 mm.
    So, without any beam expander I have...(assume that M^2 = 1.5)
    diameter = .013 * 1.5 * (38.1/4.7) = 0.158mm
    Romos
    Jan 2004
    231
    Quote Originally Posted by Romos V.
    Owen,
    Now, about your table... It will be better if gap between the sheet metal and the aluminum is more than 3/8ths of an inch. If this gap is small, the reflected heat will bend the stainless steel sheet....
    Romos,
    excellent information, as always. Regarding the reflected heat -- I could put the magnets up higher on 2.5 cm posts, and still use the aluminum plate below.
    Do you think that a larger air gap above the plate will be okay or will it still reflect heat and bend the metal?
    I remember that you use rows of angle iron that looked like LLLLLL. I can create something like that. I'm trying to decide if using the plate as a support is okay, or if I should make something that will be more complicated.
    Owen
    Jul 2004
    28
    Owen,
    it will still reflect heat but bigger gap will be better. Not only for the heat. When gap is small, small pieces from the melted metal will hit the aluminium plate, and they will go on the back of the metal sheet.
    Romos
    Jan 2004
    231
    Romos,
    thank you for your comments on my calculations. The distance to my beam expander is 33cm, so using your chart the beam size will be about 3.5mm when it goes into the expander. The beam expander is 3 times the original size so the beam will go to 10.5mm.
    Based on the equation:
    diameter = .013 * 1.5 * (38.1/10.5) = 0.071mm
    This is a great spot size. The problem will be my depth of field. This is based on the formulas shown on this site:
    http://www.parallax-tech.com/faq.htm
    Depth of field is the distance range that an object can be placed in front of the lens and still get cut. The forumula for depth of field is
    DOF = 2.5 x wavelength x ( focal_length / beam_diameter )^2
    for our laser it calculates to:
    DOF = 0.027 * (focal_length / beam_diameter)^2
    I made a chart that gives examples of our two situations.
    The first row is what happens with your laser. You have a focal length of 38 mm, beam diameter of 4.7, you get 158 micron spot size, and 1.8 mm depth of field. My current situation I have a 10.5 beam diamter, a 71 micron spot, and a small small depth of field of less than a milimeter.
    I tried to other variations. One would be if I had no beam expansion. My beam diameter would be around 3.5 (close to yours) and a slightly larger spot size. This might work, but it also may not be enough power density to cut metal.
    The last row of the chart is where I use a focal length of 4 inches with the beam expander. If I do that, I get a spot size of 190 micron, and 2.5mm depth of field.
    I know that since I may be cutting other materials I will want to have more than one focusing lens anyway, so maybe its time to look into purchasing them.
    owen
    Jan 2004
    231
    Owen,
    Romos
    Okay based on your comment I think I'll raise the height of the magnets for now and run a fan to blow air away from the cutting. I want to get something set up just so I can do some testing before making the most perfect and complete solution. One of the things that's frustrating is that I will be able to make a honeycomb support -- once I can cut sheet metal. So I want to get it working so it can start bulding parts to complete the project.
    owen
    Apr 2004
    439
    hiya owhite
    i recognize your servo's
    If you dont mind me asking some questions
    How do they run?, power?, heat? what voltage did you go with?
    What controller did you use? , working good??
    Looks like you're running the sevos 1.1 ratio. how is that working out?
    THanks
    Jan 2004
    231
    Quote Originally Posted by sendkeys
    hiya owhite
    THanks
    Here are some specs on the motors:
    http://nilno.com/laser_dir/2003_12_0...28957759165454
    here are some calculations for its power supply:
    http://nilno.com/laser_dir/2003_12_0...48459727349689
    This is a thread on cnczone that was about changes I made to the toroid:
    http://www.cnczone.com/forums/showthread.php?t=2924
    The motor drivers are gecko G320s, the motor controller board is called a Universal Stepper Controller, found at:
    http://pico-systems.com/univstep.html
    I like the UCS, the geckos, and the motors just fine. I'm told by Mariss, grandfather of gecko motor drivers, that they are oversized for my application. The problem with oversized motors if somehow the encoder were to fail, and the motor just ran at full speed, you damage everything. Now since nothing ever breaks in CNC work, the encoders couldnt possibly fail on me >>insert big eye-roll here<<
    owen
    Apr 2004
    439
    Thanks for the links and info
    Jan 2004
    231
    So I made a new rack for the top of the CNC table. Its made of 3/4 inch aluminum bar stock. Its held together with threaded rod. Aluminum tubes were cut 1 3/4 inch for spacers.
    There are neodymium ring magnets attached with small bolts in on each bar. The neodymium rings came from ebay. If you search on neodymium you'll get a million hits. Nice stuff, but you cant machine it, so I purchased the ring variety for easy bolting.
    owen
    Jul 2004
    28
    Owen,
    I made some testing for you, and I took some pictures.
    Case 1 (I don't have beam expander)
    lens distance from laser: 500mm
    focal length: 1.5"
    Material: Stainless steel 2mm
    Samples are 2 and 3cm height.
    There is no buildup of material on the back of the cut
    Jul 2004
    28
    Case 2 (I don't have beam expander)
    focal length: 2.5"
    Material: Stainless steel 1mm, and acrylic 10mm
    There is some buildup of material on the back of the SS.
    Romos
    Jan 2004
    231
    really nice information. thanks. the quality of the edge of the ss metal is amazing. I bought some extra optics so I can try focal lengths of 1.5 inch and 3.75 inch. right now I am installing the gas lines. I have a question -- do you have a filter on the oxygen line before it goes into the cutting head?
    thanks again,
    owen
    Jul 2004
    28
    I don't have any filter at oxygen line, but I clean my lenses every 2 weeks.
    Romos
    Aug 2004
    2849
    Haven't thought about lasers in a long time....How much to get started with the 100W and what is the cost of the replacement lenses....how are these protected from splatter? Thanks, Paul
    Jan 2004
    231
    Romos
    How hard is it to open up the cut quality enhancer, and the circular polarizer, and clean those optics?
    owen
    Jul 2004
    28
    Owen,
    when I say lenses, I mean the ZnSe focusing lenses only.( 1.5" and 2.5")
    They get dirty from the nozzle side and not from the sealed side.
    And you have to clean them regularly. If not, soon they will crack.
    I don't open up the cut quality enhancer and the circular polarizer.
    Romos
    Jan 2004
    231
    Hey Romos,
    I tried cutting sheet metal this weekend. It didnt work so far. I did a lot of testing of the beam size which I will post later. It looks like my beam diameter is pretty good, when I cut wood it was around 200 micron.
    The beam hits the metal, and sparks a small amount, but does not go through the metal. When I look at the spot made by the laser with a microscope, its looks like a hole is made into the metal. Some of the metal appears to be vaporized away.
    I'm looking for suggestions of what to do next. My question is, how high should the nozzle on the cutting head be away from the metal? Right now its about 2-4 millimeters away. Do you have the experience of the laser not cutting through the metal if the nozzle is too far away from the metal?
    owen
    6855
    You may need compressed air to push the melting metal through like a plasma cutter.
Page 1 of 2 12
  1. Need help finalizing plan for CNC Plasma table
    By David Bord in forum Waterjet General Topics
    Last Post: 05-26-2005, 01:16 AM
  2. CNC Plasma table plans
    By krazycnc in forum Waterjet General Topics
    Last Post: 05-06-2005, 03:51 AM
  3. Build a CNC rotary table? (longish)
    By jcolley in forum Mechanical Calculations/Engineering Design
    Last Post: 02-12-2005, 03:23 PM
  4. Rapid prototype CNC laser resin. (Stereolithography)
    By ynneb in forum Community Club House
    Last Post: 04-25-2004, 02:17 PM
  5. Cost / Price of a DIY CNC table.
    By Havic in forum DIY CNC Router Table Machines
    Last Post: 03-01-2004, 09:08 PM
