586,655 active members*
3,117 visitors online*
    Oct 2004
    198
    How do I enter comments into a Fanuc OiM?
    I'm already familiar with entering comments using the () bracket keys, but the control panel on our new Hardinge VMC doesn't have the brackets, I only have the [] brackets used for formulaes, any suggestions?
    Thanks.
    927
    Darc,
    You may not be able to do it at the control if there are no () keys..sucks I now..My OTc also does not have a "full" key pad..
    You may have to do like I did in the days of programing at the control ...after the program is built, post it to a editor and add the comments..
    I now program everything in my cad/cam software. It automatically adds the comments where I want.
    Maybe someone else knows if a OiM will take something other than ( ) for comments..my bet is not..been wrong before though.
    Nov 2004
    4
    Check parameter 3204 bit 6 or 4
    If you have the Fanuc Parameter Book. Look under parameter 3204 bit 6 or 4. Turn that on to 1. It will give you ( & ). Be in edit mode, soft arrow over two times until you see [C-ext]. This will give you ( , ) and @. Let me know if you can't find the parameter. Here's my email address [email protected]. If need more help, email me.
    Oct 2004
    198
    Thanks mavs84, it certainly worked the only thing I noticed is I need to enter a character first to get the soft menu to change first then press the right soft arrow twice, delete the character and away I go.
    Nov 2004
    4
    Darc, I'm glad I was able to help. Let me if I can do everything else for you. Let me know when your company is looking at more machines. We import Leadwell CNC into the USA. Leadwell is a much better made product then Hardinge. We also sell Hardinge in the USA in Texas. Here's my personal email address [email protected]. Let me what other info you may need. I'm also planning to vacation in Australia to next year. Talk to you later
  1. Programming PLC on Fanuc 0M
    By MetLHead in forum Fanuc
    Last Post: 02-18-2019, 06:36 AM
  2. Fanuc 3M DNC operation
    By max_c in forum Uncategorised MetalWorking Machines
    Last Post: 07-05-2010, 01:11 AM
  3. Fanuc motor ???
    By jevs in forum Servo Motors / Drives
    Last Post: 03-16-2005, 11:47 PM
  4. Fanuc 21-GA_416 Alarm-Axis Disconnect
    By lasermike in forum DNC Problems and Solutions
    Last Post: 03-10-2005, 07:49 AM
  5. FANUC coding compatability??
    By m1911bldr in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 04-24-2004, 11:10 PM
