586,975 active members*
3,150 visitors online*
IndustryArena Forum > MetalWorking Machines > Bridgeport Machines > Bridgeport / Hardinge Mills > How do I adjust the tool changer height parameter on a TNC145 (Interact 412)
    Nov 2005
    48
    Interact 412 with TNC 145 control
    HELP!!!
    Our machine has gone a bit funny and the spindle doesn't come to the right height for doING tool changes.
    The Z home height is still perfect, I double checked by recalibrating using a tool with a known offset height.
    the changer is coming in few millimeters high.
    I know that there is a parameter that tells the machine the distance from the Z home but I don't know what it is or how to get there.
    I'm meant to be milling a gearbox for a friend going to the Isle of Mann TT the day after tomorrow (Weds) so I am a little desperate to fix this quickly
    James
    Nov 2004
    3028
    I do not have the specific parameter for this. Could not dig up a manual nor a ETS for this machine. So here it is from memory since this is a antique.
    If you have the parameter, I would move the head to the tool change height, turn off the air and bleed off the pressure to allow the tool changer to move forward by hand, go to MOD and find CODE, type in 95148, ENT, this will get you into the parameters.
    Change the tool change height parameter by what you need to have the tool changer slide onto a tool in the spindle.
    George
    Nov 2005
    48
    Thanks for the reply. Hardinge UK were extremely helpful, and talked me through exactly what i needed to do.
    Would have been completely lost without those dudes, cases have been cut and delivered, and found that what they asked for was not entirely the right shape, so starting again today
    Thanks millions for getting back to me all the same
    J
    Nov 2004
    3028
    Could you please post the parameter number and procedure here at your convenience so that anyone searching these posts can find the answer.
    Thanks.
    George
  1. Hoss 16 Tool Automatic Tool Changer
    By hoss2006 in forum Benchtop Machines
    Last Post: 03-03-2011, 10:29 PM
  2. Tool Height Reference Tool
    By Don Clement in forum Tormach Personal CNC Mill
    Last Post: 03-14-2009, 09:24 PM
  3. Nl2500 Tool setter How to adjust
    By sjlbwig in forum Mori Seiki lathes
    Last Post: 02-11-2009, 11:43 PM
  4. Tool Changer picks up wrong Tool?
    By KJ45 in forum Uncategorised MetalWorking Machines
    Last Post: 03-13-2008, 12:51 PM
  5. Help with a Tool Changer Parameter
    By unionswiss in forum CNC Machining Centers
    Last Post: 10-25-2007, 07:42 AM
