Originally Posted by
CNCadmin
I'm using deskcnc with my servo system. It's a OK system the only thing I HATE is the mouse interface, their are no short cut keys. Ya is my tried and true controller software that always works with-out fail, UNLESS you do a drill cycle into a contour, than all you do is break bits, because after the last hole is drilled it pecks and agin as the machine makes a rapid move.
Paul, I'm not sure if I understand you, but perhaps you have failed to program a G80 immediately after the drill cycle is completed? This is necessary to cancel the cycle motion.
First you get good, then you get fast. Then grouchiness sets in.
