Is the following card suitable for a medium sized machine say 32" x 59". will it be able to run the large enough motors. Also do i need anything else other than the three motors if i got this item???
Delagrange Technology LLC. offers the following superior crafted item:
4 AXIS 10 AMP STEPPER MOTOR DRIVE BOARD
(4XCNC10B)
This board has improved heat dissipation and easy DB25 connector computer hook-up
Built to handle up to 10 amps max per phase per motor
Unlike some competitors, 10 amps of constant current can pass through each output
Maximum voltage on the board outputs is 50 volts
This board requires a 5 volt DC filtered and regulated power supply
Board design is for unipolar stepper motors only
ADDITIONAL NOTES:
A fan blowing on the output hexfets is required if board is running 5 amps or more per phase
Board is fully compatable with Master 5, Mach 1, Mach 2, or CNC Pro
Has 4 home switches, one for each axis and infinite limit switches, and an e-stop switch
Has 4 onboard relays that can be turned on and off with the computer software for spindle, coolant pump, drive enable
Relays rated for 10 amps at 125 vac
Board comes with 4 programmed chips, one for each axis-no more confusing dip switches-your choice of chips in half-step, two phase (single step), or wave drive (single step), please make sure to specify which step sequence chip you want for each axis.
Which of the above chips is better???
