Hi all !
A couple of week ago i finish to build my CNC and start to make some work with it. I fix on it a cheap $20 dremel like rotary tool and try some engraving with this type of cutting tool :
http://www.dewalt.com/us/products/ac...categoryID=871
But i see rapidly then this Dewalt cuting bits don't did the job and the cheap rotary tool not strong enough. I decide to buy a Dewalt cutout tool like this :
http://www.dewalt.com/us/products/to...productID=2750
but from a another trademark. It come with 2flutes general cutting bits and work much better then my previous dremel tool and dewalt bits. I can ajust the speed from 15 000rpm to 30 000rpm on the rotary tool.
But my problem is : I always burn my bits in wood ( 2x4 wood lumber ) or MDF.
Here is my setting :
Router RPM: Slow as possible ... 15 000 rpm ( more speed i put on it , faster the bits come to burn )
FeedRate : i try between 60mm and 90mm per minutes but always burn
EndMill Flutes : 2flutes
EndMill Diameters : 1/8'' and 1/4'' ( 3.2mm and 6.4mm)
I broke my 1/8'' bits at 90mm/min in MDF ( probably too fast , not sure )
And i burn ( not too much but just enough ) my 1/4'' at 60mm/min and 90mm/min in 2x4 pine lumber.
Any body can help me with that please?
I don't know what i need to do .... push higher the FeedRate .... my rotary tools turn too fast ( i see then sherline router turn between 70 and 2800rmp but see a lot of homemade CNC with dewalt like rotary tool) .... or my bits is too cheap.
I planning to buy some 2 or 4 flutes carbide endmill on Ebay but i don't want to buy this for burning it again.
thank and so sorry for my poor english
