586,655 active members*
3,592 visitors online*
IndustryArena Forum > MetalWorking Machines > Haas Machines > Haas Mills > Out of control Rigid Tapping.
Results 1 to 11 of 11
    Sep 2004
    209
    Earlier today, I was setting up a job I've run several times before. During verification, the first of the two G84's caused the mill to do something I've never seen before. It is probably best explained in this video: [ame="http://www.youtube.com/watch?v=034I-YXibOc"]YouTube - Crazy G84[/ame]
    In the video, rapids were set at 25%. If they are at 5%, the 'bouncing' is less severe and slower; at 50%, it is more severe and faster. I didn't even want to try 100%.
    I tracked the problem down to the "RAPID -> HS FEED" parameter. I changed it to "1" a while back to use interpolated rapids instead of dogleg rapids. When I changed "RAPID -> HS FEED" back to "0", the problem dissappeared.
    My mill is a 2007 MiniMill, with a version 14.04C controller.
    Here is the portion of code:
    T6M06
    G90
    S1500
    M08
    G0X-.325Y-.394
    G43H06Z.25
    G84X-.325Y-.394Z-.35R.25F37.5
    X.325Y-.659
    G80
    M09
    Has anyone else come across this problem before? Is there anything that Haas will do for an out-of-warranty machine with a bug? I would really like to use interpolated rapids because it allows me to take full advantage of my CAM software (ProNC) and minimizes one potential source for crashes.
    For now, I will switch "RAPID -> HS FEED" off every time I want to use G84, but that is not a long term solution for me. If I forget to turn it off, G84 will cause a crash. If I forget to turn if on, the dogleg rapids could cause a crash. Damned if I do, damned if I don't...
    Thanks in advance,
    Chris
    Jul 2005
    12177
    Quote Originally Posted by ckirchen View Post
    ...... Is there anything that Haas will do for an out-of-warranty machine with a bug?....
    Get hold of Haas-Apps.
    Jul 2005
    12177
    It is difficult to tell from a video but your spindle seemed to be running fairly slow; what was your rpm?
    I have found that when something like 100 or 200 rpm is used for rigid tapping the spindle speed does not settle down. How this could interact with the feed I do not know but if you are going slow try speeding up and see what happens...several inches above the part.
    Sep 2004
    209
    Spindle speed is at 1500 rpm.
    927
    Looks to me like you didn't cancel the drill cycle (that I assume preceded the tapping cycle)..I see no G80..but I can't see the entire program..Just what I would guess..
    Sep 2004
    209
    On the line preceeding the toolchange, I have a G80.
    Initially, I thought that I had somehow changed the G84 to a G83. Or even peck tapping. But if you watch the video closely, you can see the tool pecks down and then pecks up. Also, the depth that it goes to is not the Z-.35 that I commanded; it is more than that. When the rapids are set to 50%, it goes even deeper.
    Nov 2007
    1702
    Lemme' ask you a stupid question: have you copied the program and deleted everything before and after that part, then tried it (tapping air)?
    I'd approach it systematically. If deleting everything else fixes it, then the problem is elsewhere.
    If not, I'd delete the second hole location and try it.
    If that didn't work, I'd try changing the feed or RPM.
    You'll eventually get to something that makes it not do that. At that point, you can work backward to a solution.
    Could this be something between the retract plane and some retract setting elsewhere in the control? I'm not in front of my machine right now but I wonder if some really large retract distance in the settings might be conflicting with the retract plane in G84.
    Greg
    Sep 2004
    209
    I too thought it might be a certain combination of parameters that was causing this behaviour, so I tried the following:
    - faster/slower rpm
    - faster/slower feed
    - starting on the same tool
    - starting with a tool change
    - rapids at 5%, 25%, and 50% (not brave enough to try 100%)
    - G84 as part of the main program
    - G84 as part of short program (set speed, feed, then G84 X_ Y_ Z_ R_)
    - G84 in MDI
    - coolant on/off
    - one hole/lots of holes (first hole is always bad, remaining are not)
    - tool length offset/no tool length offset
    - starting at retract plane/starting above retract plane
    - and a few more that I can't recall off the top of my head
    Unfortunately, the only thing that removed the problem was turning off "RAPID -> HS FEED".
    I plan to call my HFO and/or Haas Help Desk on Monday.
    Dec 2008
    319
    Try turning setting 133 OFF. Haas told me this sometimes causes problems.
    Tim
    Sep 2004
    209
    Repeat rigid tap is not on.
    The Haas factory has confirmed that, on older controllers, interpolated rapids (i.e. RAPID -> HS FEED set to 1) can not be used with canned cycles (G81, G82, G83, etc.).
    Only the newest control (software v16) can have interpolated rapids on all the time. Previous versions were just not designed to do so; the only commands that should be used are G00, G01, G02, and G03.
    Sep 2007
    34
    this is a dumb quick fix how about a dummy first hole that is off the part.
    I know it wont fix the problem but you could be running the job.
    last suggestion put a M0 before the tap so you could run the rapids at 100% then change them to tap.
  1. Rigid Tapping
    By Teps71 in forum Milltronics
    Last Post: 03-29-2016, 01:23 PM
  2. Replies: 24
    Last Post: 05-01-2014, 07:02 AM
  3. Tapping head or rigid tapping
    By Gregory_C in forum Syil Products
    Last Post: 10-18-2008, 06:49 AM
  4. Rigid tapping or tapping head
    By kentavv in forum Charter Oak Automation Support Forum
    Last Post: 09-24-2006, 06:08 PM
  5. Rigid tapping on a BPT TC1G w DX32 control
    By machintek in forum Bridgeport / Hardinge Mills
    Last Post: 01-02-2005, 02:06 AM
