586,414 active members*
3,064 visitors online*
IndustryArena Forum > OpenSource CNC Design Center > OpenSource Software > l298 l297 driver 2A with stepper 3A help
    Mar 2007
    46
    i have done my pcb l298 l297 2A
    its work perfect with stepper 1A
    but when i change with 3A stepper i uses 0.666 vref at paralell 2.1
    with pc power supply 12v
    but l298 heat abnormal more then 120 degre c
    i put aluminuim and 3 fan cooler but chip very heat
    did some 1 have solution haw i do
    thanks
    stepper =
    Typ : bipolar / (unipolar)
    Strom : 2,2 A (3,0 A) / Phase
    Haltemoment : 1,65 Nm (1,3 Nm)
    Widerstand : 0,9 Ohm / Phase
    Induktivität : 2,2 mH / Phase
    Attached Files Attached Files
    Jun 2003
    3312
    The L298 is rated a maximum of 4A ehn both channels are paralleled. Typical stepper configuration is 2A max.
    Phil, Still too many interests, too many projects, and not enough time!!!!!!!!
    Vist my websites - http://pminmo.com & http://millpcbs.com
    Mar 2007
    46
    What's your main
    did this work ?
    Mar 2005
    305
    yes, u can use 2A driver with 3A motor, but it is lower torque
    Jun 2003
    3312
    Yes you can run a motor at less than it's rated current. The result is lower torque.
  1. Problems with stepper driver (L297 and L6203)
    By MagooT in forum Open Source Controller Boards
    Last Post: 09-07-2012, 12:35 PM
  2. L298, L297 Stepper Driver
    By abbe in forum Open Source Controller Boards
    Last Post: 07-01-2012, 04:25 PM
  3. Problems with l297/l298 based driver
    By Jykke in forum Stepper Motors / Drives
    Last Post: 01-13-2012, 06:44 PM
  4. L298/L297 strange stepper motor noises
    By cnc kiwi in forum Stepper Motors / Drives
    Last Post: 12-26-2007, 05:18 PM
  5. L297-l298 stepper board design
    By watchman in forum Stepper Motors / Drives
    Last Post: 03-29-2007, 03:00 PM
