586,266 active members*
3,777 visitors online*
Results 1 to 7 of 7
    Mar 2009
    11
    3D dxf to g code converter
    I used to be a happy user ogf ONeCNC til I lost the USB key and they demanded 4K to buy an entire new seat! Forget them- I bang most of my simple files out in notepad- drilling, mortices, straight moves. But I need something that will take a dxf file of a surface I draw in Cadkey, make lots of planes at the stepover increments and intersect the planes and surface for a quick and accurate toolpath), then can send a dxf file out. All I need is something to read the dxf and output G01 moves in X, Y and Z, all one line. Don't need coolant, Mcodes, all that fancy stuff.
    I can't seem to find anything free or cheap which does all three axes. Help? Seems like it should be a cinch to write up.
    If you can export in as an .stl file, then try Freemill. www.cncportal.com
    Mar 2009
    11
    Has to be dxf, stl or vrml won't work
    On trying that it seems that stl and vrml files need polygons or some sort of face, the files I am using consist of lines or polylines, occasionally arcs. In other words the geometry is only basic line/arc entities which I need to generate g code and coords for. I attached the dxf file
    Apr 2005
    3634
    The dxf didn't upload...
    Free DXF - vectorink.com
    Mar 2009
    11
    DXF file attached?
    Here is a retry of the file
    Attached Files Attached Files
    Jan 2006
    758
    Quote Originally Posted by gaanes View Post
    Hi there,
    from what you say you effectively want to gcode a .DXF toolpath that has nodes distributed through 3 dimensions.
    CamBam or gmax/CNC_Toolkit can generate gcode for this kind of .DXF
    EDIT: See the image below for your file loaded in CamBam FREE Beta...
    Hope this helps
    Danny
    What one man can do another man can do..
    BitMaps to Models, 3D2Relief, tutorials and FREE CNC Software http://cnc4free.org
    I have an AutoCAD macro that'll work for 3D polylines, but not arcs. But you'd need AutoCAD 2002 or newer to use it.
  1. eps to dxf converter
    By studysession in forum Autodesk
    Last Post: 05-25-2009, 11:32 AM
  2. Looking for a .dxf to G-Code converter...
    By sciontim in forum OpenSource Software
    Last Post: 06-03-2008, 06:30 PM
  3. suitable g- code converter software for Mitsubishi MT Developer?
    By 19darren84 in forum G-Code Programing
    Last Post: 04-06-2007, 03:41 AM
  4. help CAD CAM converter
    By kiethnt in forum Uncategorised CAM Discussion
    Last Post: 03-24-2007, 03:29 PM
  5. Ace Converter G-code Question
    By ljoe1969 in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 01-22-2004, 06:18 PM
