I am wiring my differential encoder and I have a question about which resistor to use. According to the manual--
For long cable lengths (beyond 3 meters), it is may be necessary to terminate
differential pairs with 120 Ohm resistors (connected from A+ to A-, B+ to B- etc). A 10
nF capacitor can be connected in series with termination resistor to reduce encoder current
consumption. Terminators can be soldered inside D-Sub connector housing or connect them
externally to EXT connector.
My local Radio Shack only has 100 Ohm and 150 Ohm resistors. Which of these should I use, or do I have to order a 120 Ohm resistor?
Is it ok to use ceramic disk capacitors ?
thanks
Steve
