586,103 active members*
3,298 visitors online*
    Aug 2003
    11
    Question Ball Bearing Size
    Does anyone know the diameter of the ball bearing in a thk hsr 20
    bearing block I have measured mine and have found one ball smaller
    than the rest , as i have brought off ebay i am not sure if they have been replaced with a wrong size .
    sizes measured are 3.969mm plus one at 3.175mm
    Nov 2004
    260
    Just guessing but could it be that the smaller ball is
    just used as a spacer.
    May not be enough room for one of the proper size?
  1. Ballscrew Basics
    By Swede in forum Linear and Rotary Motion
    Last Post: 04-25-2024, 08:37 AM
  2. Ball bearing encoders - DIY?
    By Mcgyver in forum CNC Machine Related Electronics
    Last Post: 11-27-2005, 07:25 PM
  3. Ball screw angular contact bearing block
    By dowling177 in forum DIY CNC Router Table Machines
    Last Post: 03-15-2005, 09:03 AM
  4. strange bearing preload threads on ball screw
    By mxpro32 in forum Mechanical Calculations/Engineering Design
    Last Post: 03-11-2005, 03:07 AM
  5. Ball Screws and machine size?
    By swiftden in forum DIY CNC Router Table Machines
    Last Post: 02-03-2005, 11:02 PM
