586,115 active members*
3,323 visitors online*
IndustryArena Forum > CNC Electronics > Stepper Motors / Drives > 2 phase driver & 4 phase 6 wire stepper HELP!
    May 2009
    Question 2 phase driver & 4 phase 6 wire stepper HELP!
    :wave: My first post.
    Hi all just have a question about phases.
    I have a Mechatronics 4 axis driver board
    and some 6 wire steppers.
    The driver board handles Uni or Bi polar 4 to 8 wire steppers
    My understanding was that all I had to do is not use the middle
    wire of each coil. Fair enough.
    Then I found out that my steppers are 4 phase. HUH?
    My Question is that if I use these steppers as 4 wire then
    does this change the phase??.
    I don't understand the phase thing at all ,hence the question.
    I opened up one motor to see if that would help me
    figure it out but ended up more confused after seeing
    it had 8 sets of windings.
    Any help or advise would be greatly appreciated
    Mark
    Jun 2003
    3312
    Phil, Still too many interests, too many projects, and not enough time!!!!!!!!
    Vist my websites - http://pminmo.com & http://millpcbs.com
    Sep 2008
    142
    Please detail exactly which motors you have so that I can research them on the web for you.
    Are you ok with an ohmmeter? can you post a sketch of how the field coils are connected?
    Make sure that you measure between sides, that is to see if both are also connected to each other, which is possible.....add ohmage of each coil, either name (color) or number the connections in some manner....
    regards
  1. 5 Phase/ 5 wire stepper drivers.
    By jonandyev in forum Open Source Controller Boards
    Last Post: 09-24-2020, 06:37 PM
  2. Sine wave for 5 phase 10 wire stepper (non-stared)
    By terrym in forum LinuxCNC (formerly EMC2)
    Last Post: 09-29-2008, 10:57 AM
  3. 5-phase stepper driver?
    By skandragon in forum Stepper Motors / Drives
    Last Post: 04-04-2008, 03:15 AM
  4. 3-phase stepper driver inquiry
    By extrapilot in forum Stepper Motors / Drives
    Last Post: 07-26-2007, 09:16 PM
  5. Phase shifted stepper driver?
    By Tinmuk in forum Stepper Motors / Drives
    Last Post: 01-24-2006, 05:17 AM
