586,655 active members*
3,148 visitors online*
IndustryArena Forum > CAM Software > FeatureCAM CAD/CAM > new guy needs help. how to set tool boundaries
    Oct 2008
    8
    I have a part that created in Solidworks then imported. I manage to figure out the program (coming from something much simplier rhinocam) and setup my tool list, machine setup and set up the various cuts etc.
    In rhinocam i could set the stock to whatever the size and it would only mill a pocket with the part inside but with FC it wants to remove all the waste stock that i had set. If i make the "virtual stock" smaller than my physical stock i get gouging and tool breakage as it wants to mill past the "virtual stock".
    I found a post where they said to use the "total stock" in the milling tab, when i use this all my flats are the height of the stock and doesn't get touch by the tool.
    In rhinoCam when i set the stock size this is what it cuts and when i set up my machine i can place all my clamps on the outside of this box and not worry about gouging into the remaining stock that my hold down clamps are on.
    I've played with GibbsCam at my friends shop and they a have a feature called "stay in stock" in the process tabs that does it much like rhinocam.
    Sorry long post for probably a quick and easy answer but i'm newbie to CNC.
    Thanks.
    Jun 2005
    69
    Check out using a "curve as boundary" and the action will stay inside of it.
  1. Changing tool diameter in the tool offset screen
    By Vern Smith in forum Haas Mills
    Last Post: 05-09-2022, 05:25 PM
  2. orient tool for tool change Hall effect?
    By Luslugger in forum CNC Machining Centers
    Last Post: 04-25-2009, 12:24 AM
  3. T slot tool post with drill bit tool holder
    By brucesu1 in forum CNC Tooling
    Last Post: 06-09-2008, 11:04 AM
  4. G43.1 - Tool Axis Direction Tool Length Compensatioin
    By EngTech in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 12-06-2007, 11:01 AM
