586,094 active members*
3,747 visitors online*
IndustryArena Forum > CNC Electronics > Gecko Drives > G320 and Encoder compatability?
    I have an encoder with A+ and A- and also a B+ and B-.
    So I have 4 wires that I need to connect to the 2 encoder terminals on the G320. Should I wire both A+ and A- onto the same A terminals?
    Cheers
    Gav
    Mar 2004
    1806
    ignore the A- and B- as they are the inverted signals of A and B respectively. Also, verify the current draw on your encoder. I must be 50ma or less to be powered from the Gecko, If it is more, you will need to provide a separate power supply and follow the instructions which can be found on their web site.
    Art
    AKA Country Bubba (Older Than Dirt)
    Sep 2005
    1195
    What need to take attention to get encoder compatible with gecko 320. I have a plan to buy hanyoung (korean made), it is rotary encoder, how do I know that this encoder work with g320?
  1. encoder cpr ?? g320
    By chrisw765 in forum Gecko Drives
    Last Post: 03-09-2009, 05:54 AM
  2. UNKNOWN ENCODER & G320.
    By salman in forum Gecko Drives
    Last Post: 01-02-2008, 05:45 PM
  3. encoder question for G320
    By CNC Darren in forum Gecko Drives
    Last Post: 11-15-2007, 07:14 PM
  4. Replies: 0
    Last Post: 04-07-2007, 05:31 AM
  5. encoder question for use on G320
    By Runner4404spd in forum Gecko Drives
    Last Post: 12-09-2005, 05:32 AM
