My lab has just dusted off an old Minitech Mini-Mill/2 purchased in 1993. It has been sitting without much use since it arrived, and we have lost all documentation for it. However, the Minitech website claims that Minitech's customization of the Mach3 software should work with every machine they have ever sold back to their founding in 1983. We downloaded the Minitech customization of the Mach3 software but can not get the motors to spin.
Two electrical engineering graduate students spent a couple hours with a oscilloscope and probe and chip data sheets and determined that the 4N28 opto-couplers that are part of the mill's electronics and isolate the parallel port are incapable of passing through a pulse any shorter than around 100 micro-seconds. However, the longest step pulse we can seem to get Mach3 to send is 15 micro seconds long. I believe that Minitech would have tested out their customization of Mach3 before making the claim that it will work on every machine they ever sold, so I come to you asking if there is anything obvious I have missed. The only place in software I saw that allowed a change in the step pulse length was in the Motor Tuning configure window. The label over the text input box for setting the pulse length is labeled for a 1-5 us range. But typing in any number larger than 1 to 15 micro seconds just makes it reset to 15 micro seconds (which is odd considering the label says it will only accept pulse widths between 1 and 5 micro seconds.) We have tried both active high and active low logic options as well.
If any one has experience with something similar, any suggestions would be greatly appreciated. Minitech tells me that they are unlikely to find documentation for this old mill.
Thanks everyone in advance.
