Originally Posted by
Ed from NY
I'll probably leave the old red panel on the mill head, but disconnected.
I have started to take things apart for the upgrade.
A few things I'm not sure:
1) The old "PC board" had a 36-pin female centronics connector (pic #2) for the parallel cable. The new board has some sort of modular socket (pic #3). Not sure how to go from one to another.
That looks like a 20pin IDC (ribbon) connector, you can buy the IDC header and 20 conductor ribbon easy enough, the trick is connecting the other end, if it is 36 pin D, then you can get a 36 pin to terminal breakout board.
The other way is to strip the other end of the ribbon and connect the wires individually to a D connector.
The IDC header can be snapped to the ribbon in a vise.
The header pin 1 is marked and the ribbon has a red stripe on one edge.
Al.
Albert E.
