Well we loaded our first file from a BobCAD created toolpath. BobCAD came with Predator CNC Editor for Bobcad, and it was pretty simple to load the file into the control...
However here is the issue we had.... The first try worked, but on the CNC88 screen there was a bunch of gibberish as the file was loading.... being the first time, we thought nothing of it... well after it completed, the program was nowhere to be found... So we checked and had to set the parity and baud on the PC, and re did the file transfer...
This time we could see the code on the CNC88 monitor as it loaded.... However we quickly ran out of memory...
There are no other programs in the machine, but this time it only transferred about 1200 lines...
My question is - did the first file that we messed up get loaded into the machine somewhere? We are not able to see it under the programs, but maybe since the file transfer was incorrect there is a bunch of junk hogging space??
Or - is it that the CNC88HS can only have a few thousand lines of code? The NC file we loaded was about 52,000 lines of code....is this an abnormally huge file? It is a fairly simple part - just a few holes being hogged out, and some drill/tap routines...
Thanks!!
