586,060 active members*
4,389 visitors online*
IndustryArena Forum > MetalWorking Machines > Haas Machines > Haas Mills > Haas Super Mini-Mill and Haas Trunnion Table
Results 1 to 7 of 7
    Apr 2008
    75
    Would I be able to use a Haas Trunnion table, such as:
    http://haascnc.com/details.asp?ID=TR...otaryTreeModel
    with a Haas Super Mini Mill 2 (with the 4th- and 5th-axis enabled)?
    Nov 2007
    1702
    I'm going to say no. Even if it would fit in there, you wouldn't have enough room for tool changes (they'd whack the left side of the trunnion).
    You could get a Super Minimill (not the '2'), then get the 4" Z axis riser block. That might buy you enough additional clearance. It would be tight, though.
    Why would you limit yourself that way? Why not a VF-1 or 2?
    Greg
    Apr 2008
    75
    Well, I already have the Super Minimill 2.
    Nov 2007
    1702
    Well, in that case, you can see the dimensions on the web page. Do you think you could get it to fit in there? How big are the parts you need to make? Maybe you could get the TRT160 to fit in there (less hardware on the left side of the table).
    Having the machine, you understand the problem: the tool changer pulls the holder down then sweeps the envelope as it swaps with the new tool. That's going to really restrict how much room you have, depending largely on the length of tools you expect to use.
    Greg
    Jul 2005
    12177
    No, complete, utter, emphatic NO. Too heavy.
    Machine weight on Super MiniMill 2 Table is 500lbs, TR210 weighs 800lbs.
    EDIT: TR160 is 425lbs but even so I think it is too long at almost 40".
    Nov 2007
    1702
    Whataya' think of the TRT160 (the one without the other swivel)? That's the one I was suggesting, though it's still hovering at 400 lbs.
    Greg
    Jul 2005
    12177
    That is a possibility but I would check the weight distribution when the table was all the way at the limit of travel; the 500 lb is 'distributed'. I think centered about the midpoint would qualify but if most of the weight was toward one end it may not be a good idea.
  1. Haas Trunnion Post for Surfcam
    By kojack in forum Surfcam
    Last Post: 04-02-2015, 03:13 PM
  2. Engraving on an Arc using Haas Super Mini MIll
    By chop5280 in forum Haas Mills
    Last Post: 02-25-2015, 09:36 PM
  3. acra cnc to haas super mini
    By metlcutr55 in forum Haas Mills
    Last Post: 08-20-2008, 02:48 PM
  4. HELP!! Haas Super Mini Mill
    By CountBraden in forum Haas Mills
    Last Post: 07-07-2008, 12:20 AM
  5. HAAS Super Mini Mill
    By Ford25 in forum Haas Mills
    Last Post: 09-07-2007, 02:01 PM
