586,312 active members*
3,710 visitors online*
Results 1 to 9 of 9
    Dec 2003
    218
    Mach 3 DRO Bug ?
    Since recently calibrating my axes using the wizard in mach 3 my DRO's are not displaying what they are told to.
    For example if i type g0 z-20 my dro for z shows -19.997. Why is this happening, do I need to worry ? Is this a known bug ? Seems like it might be a rounding error or something. Is there a way to fix it ?
    Regards,
    Dom
    Dom
    http://www.ukrobotics.com/projects
    35538
    I'ts related to your steps per unit setting. I'm guessing that with your current settings, Mach can't actually get to 20. 19.997 is the nearest step. If it moved one more step, it would go past 20.
    Dec 2003
    218
    I wonder if I can change my steps per unit very slightly to make the dro read right without harming accuracy. The calibration feature does end up with very long numbers after the decimal point.
    Dom
    35538
    Don't do that. Set the machine to cut accurately, and don't worry about the DRO. What are your steps/mm set to?
    Dec 2003
    218
    804.8289738
    Dom
    35538
    Quote Originally Posted by UKRobotics View Post
    804.8289738
    For the Z? with that, it seems like it should display 19.999. Even so, I wouldn't worry about it. May be some rounding going on somewhere that I'm not aware of, but .003mm isn't much.
    Dec 2003
    218
    I think that figure I gave you was for the X. I just picked the top of the list as an example.
    I know the actual ammounts we are talking isnt much, but its little things like that which irritate me. After putting so much time and money into this retrofit, the least it can do is display the right digits on the dro :P
    Dom
    35538
    It is. If 20mm = 16096.579476 steps, you have two choices. Move 16096 steps or 16097 steps. The only way to have the DRO's always be exactly what you want would be for your steps/mm to be 1000. That way 1 step = .001mm
    Jul 2007
    887
    Gerry is right here. The DRO shows where the control thinks it has put the machine axis. If the drive system (motor, encoder, screw etc) can't resolve to exactly the position the program tells it to it will stop as close as it can get without overshooting. If one more step means it will overshoot that step won't be sent out.
  1. Configuration Mach 2 to Mach 3
    By cnc-mike in forum Machines running Mach Software
    Last Post: 11-06-2008, 02:43 AM
  2. Confused: Mach Turn, Mach Mill, Mach 2/3 ?
    By CanSir in forum Mach Software (ArtSoft software)
    Last Post: 02-16-2007, 11:41 AM
  3. Mach 3 no spindle - but OK in Mach 2
    By zcases in forum Mach Software (ArtSoft software)
    Last Post: 07-31-2006, 01:38 PM
  4. Moving to mach 3 need exact mach 2 screen
    By carlnpa in forum Mach Software (ArtSoft software)
    Last Post: 12-11-2005, 10:00 PM
  5. will mach 2 or mach 3 work for 4 axis cnc?
    By Runner4404spd in forum Mach Mill
    Last Post: 10-05-2005, 05:44 PM
