Hello!
1. I cut a raptor from foam
2. To a prowolf has tried different (02, 03, 04, 05, 06)
2.1 speeds and temperatures has tried the different
3. It is tense, properly
4. Behind carriages is in time
5. The snivel on a wire is not present
6 foam without dust
But why on co-ordinates 1, the wire leaves in a zero, and in positions 2, does not reach to necessary co-ordinates.
And even on the first co-ordinates any more accuracy. The wire comes at the left. The right exit also is not exact, it is visible on a picture.
In investments I result options, drawing and a code. Pls reed the glitch obvious, is more true in my options Mach3.
In a zip G-code ÓÏ and mine xml
http://www.golodranci.ru/444.jpg
http://www.golodranci.ru/111.zip
tanks
sorry my english
