586,104 active members*
3,226 visitors online*
IndustryArena Forum > MetalWorking Machines > Hardinge Lathes > Need Help With CHNC Collet Closer
    Dec 2007
    I bought an old CHNC with no control on it two weeks ago. Spent about a week worth of work on it ( thanks to company furlough). I replaced the servos with steppers and also replaced the spindle motor with a Hanning 220V 2kW motor. I also replaced the old spindle feedback with a spindle index pulse assembly the way MACH3 likes it. I did my initial testing with with a G540 since its so darn simple and was running both axes at 120 IPM with a 48V supply.
    I then started the task of getting the collet closer running (vari-grip type). I haven't working with something like this before and was wondering if anybody had a manual or instructions on the collet installation and removal process on a CHCNC hardinge lathe?
    Daniel
    Jun 2005
    1015
    the collet closer is fairly easy to use. there are four bolts on the collet closer (spindle side) that need to be loosened, once these are loose the closer can spin free of the spindle. this rotating motion will turn the drawbar and cinch up your collet. the varigrip assembly allows adjustment for collet use vs chuck use. personally i leave mine with the rings spread fully apart giving me 3/8 travel on the closer. also i don't let collets close with nothing in them.
  1. Collet Closer
    By Clark in forum Bridgeport / Hardinge Mills
    Last Post: 11-15-2008, 09:19 PM
  2. Bridgeport Romi Collet Closer
    Last Post: 11-01-2008, 02:04 AM
  3. Need TL-1 Collet closer
    By john whidden in forum Haas Lathes
    Last Post: 03-04-2008, 08:07 AM
  4. WTB collet closer for a Hardinge CHNC
    By N4NV in forum Uncategorised MetalWorking Machines
    Last Post: 01-10-2008, 05:43 PM
  5. FS? collet closer for TL-1
    By Mark Hockett in forum Haas Lathes
    Last Post: 07-09-2007, 06:12 AM
