586,469 active members*
3,713 visitors online*
Results 1 to 14 of 14
    Feb 2005
    78
    My new Hot Wire build
    Hi All,
    I have wanted to do some wings, foam, glass laminate for quite some time. When I have looked at it in the past I couldn't find good software. Now that I am back at it I see that Profili (http://www.profili2.com) has come a long way it's really great. What I needed was a machine to cut some foam with!
    I decided last Sunday to start with a hot wire and this is as far as I have gotten in a week, mostly evenings. The design is mostly done and so there will be few delays now except that the next three weeks is going to be really busy. :tired:
    The machine will have a cutting area of 1000mm (wide), 800mm (deep) and 300mm (high), this was just the length of the materials I had at hand. I have attached some photos for all to see, I will post the drawings when I am done with it. I couldn't bring myself to use drawer runners and such but I am going with M10 threaded rod (stainless, Vesconite nuts), I can do around 1600mm/min reliably with that which should be fine for foam. I haven't decided on the control method for the wire temp, I have a few designs and will post them here closer to the time.
    Enjoy!
    Greg
    www.cncdirect.co.za
    Feb 2005
    78
    Cool A little bit of progress..
    Hi All,
    Things are moving slower that I had hoped, should have been cutting already!
    I decided to make a few parts over but most parts are done now and the design is nailed down. I am using a pneumatic cylinder for the wire tensioning, I can control the tension by varying the pressure and I have 300mm stroke which is almost the corner to corner difference while four axis cutting.
    I have been giving some thought to an electronic temp control for the wire, I will post details here a little later, works with an SG3525 PWM chip, I will add a shunt resistor to measure the current and as the voltage is fixed I can measure the wire resistance this way. The resistance and the wire temperature should be proportional and I hope to acheive very accurate control like that. Need some more thinking...
    I've attached the latest pics.
    Enjoy!
    Greg
    www.cncdirect.co.za
    Attached Thumbnails Attached Thumbnails SoFar.jpg   VertAxis.jpg   WireGuides.jpg
    Feb 2005
    78
    Talking Almost there!
    Hi All,
    I've put in a few hours lately, I've been at it for two weeks now but things are coming together. I will run it tomorrow and hopefully cut something!
    I am thinking of making the table (MDF part) into a chamber with a port for the vacuum cleaner. I will put a few holes through the top and then use the vacuum to hold the foam down. Any ideas?
    The electronics is ready too, I have a piece of 14R/m wire (of unknown origin) and I can drive it at 50V and 3A, hopefully enough, I'll know tomorrow. It is based on the SG3525 PWM chip and is very efficient, the mosfet is rated for 55V but if necessary I can change it to get 100V.
    The wire runs through two high temp guides, I have drilled 0.6mm holes in each as it the smallest drill I have, will have to see how it works.
    Enjoy!
    Greg
    www.cncdirect.co.za
    Attached Thumbnails Attached Thumbnails WireControl.jpg   Tensioner.jpg   Side.jpg   Front.jpg
    Sep 2003
    1113
    Looking good!
    Will be watching/waiting to see how the pneunamatic control to tension the wire (as it heats up and sags) works out.
    Man-in-the loop for control I guess. But gotta be better than using a pair of pliers!
    Cheers - Jim
    Experience is the BEST Teacher. Is that why it usually arrives in a shower of sparks, flash of light, loud bang, a cloud of smoke, AND -- a BILL to pay? You usually get it -- just after you need it.
    Feb 2005
    78
    Smile First cuts!
    Hi All,
    I made the first cuts tonight, heat was in the mid range and I think it was too hot which is better than the alternative. Tensioning works great, you can watch the little block slide in and out, ran it at 1 bar, dia. 16mm cylinder which is about 2kg of tension, if I reduce the wire temp I am sure I will have to increase the pressure.
    Problems I had were keeping the block stable, it bent and twisted while it was being cut, I need to think about that vacuum table seriously!
    Enjoy!
    Greg
    www.cncdirect.co.za
    Attached Thumbnails Attached Thumbnails First Cut.jpg   Machine.jpg   Cylinder.jpg
    Apr 2005
    438
    Hello Greg
    Noticed you have not posted since June so this is a belated congratulations on making a great looking foam cutter. I like the clean, uncluttered look of it. And it looks like you kept the individual parts to a minimum.
    I have been rolling the idea of a foam cutter around for the last 2-3 months and my idea is much like yours except mine uses more parts. I’m going to change mine to incorporate some of your ideas.
    Feb 2005
    78
    Been cutting planes like crazy!
    Hello lovebugjunkie,
    Thanks for the kind words, my shop is a real mess at the moment, I had to remove the roof while doing some building work! I will post some photos of the cutting when things return to normal (and all the mess is cleaned up!).
    The PWM controller that I made works a treat, I am running at 80V and with the wire I have, 1.5 A for Polystyrene and around 2.1A for Polypropolene. The wire has a dull red glow to it when cutting EPP but I get a good finish. Cutting EPS at around 500mm/min and the EPP at around 320mm/min. When things are back to normal I have a few new designs to try.
    Profili is a great package for the wings, the only one I have found that can do the interpolation correctly, they are bringing out a new package soon for doing fuselages!
    I am using DeskCNC with a custom post that I wrote for all the parallel cutting.
    Greg
    www.cncdirect.co.za
    Mar 2007
    7
    Hi Greg
    A really neat piece of kit 10/10 your tensioning idea is great.
    Mar 2007
    7
    Hi Greg
    what 'Hi Temp material are you using as guides, pcb?
    Feb 2005
    78
    Cool
    Hi Garth,
    I don't know what it is called, came from the Tufnol people, looks like a reddish fibreglass. Works a treat!
    Cheers,
    Greg
    Feb 2005
    78
    Cool Circuit diagram for wire temperature control.
    Hi All,
    Here is the wire temperature control that I am using, the files are in Eagle format which you can download from www.cadsoftusa.com/ for free. They were done in a bit of a hurry but the circuit works great and you can fit a volt meter (0-1V) to give you an indication of the current flowing. For my wire I use 2.1A for EPP and 1.5A for EPS.
    Let me know if you need more info.
    Cheers,
    PS You will need to rename the files after downloading, delete the .txt and put the point before sch and brd (i.e. PWMController.sch etc)
    Attached Files Attached Files
    Oct 2007
    187
    Hi Greg,
    I am looking at Profili as software for my machine. Any more thoughts on how good it is, ease of learning, etc now you have presumably been playing with it for a while?
    Have you used the fuselage software?
    Jason
    Feb 2005
    78
    Cool Profili is great!
    Hi Jason,
    I am very fond of Profili for the wings. It has its quirks, one is defaulting to G21 (inches) when I cut in mm but a little manual editing of the code and it's fine. The database is extensive and I usually choose an airfoil that just kinda looks right as I don't know any of the math. One thing it lacks is a means to cut the hinge line correctly, and so I usually add a full depth spar at the hinge line and two smaller one's before and after. I then manually edit the G-code to delete the lines in between and this gives me the nice inverted 'V' shape that I need. My machine is being moved at the moment but I can take some photo's if what I have described is not clear.
    I use DeskCNC for all the parallel cutting, I have written a custom post that allows me to do parallel cutting on the four axis machine. I will when I am back 'in the business of cutting' create a second Mach profile that will use slaved axes, this will mean that I can use circles on the parallel cutting (although thinking about it perhps its not important... ??).
    I haven't tried the DevFus yet, I have poked at it but didn't spend any time. Perhaps I need a specific project to inspire me to try it (we have summer holidays coming up!).
    Cheers,
    Greg
    www.cncdirect.co.za
    Oct 2007
    187
    Hi Greg,
    thanks for the info. I get what you mean about the hinge line approach you take. A nice way of doing it.
    Jason
  1. Newbie - To build or not to build Router/Plasma Table
    By dfranks in forum Waterjet General Topics
    Last Post: 04-08-2011, 05:16 AM
  2. I have 6 wire motors can I use a 4 wire driver
    By Musick7 in forum Stepper Motors / Drives
    Last Post: 05-06-2009, 04:39 AM
  3. power supply size? for multi wire (total 250 inches of wire)
    By DanOSB in forum CNC Wire Foam Cutter Machines
    Last Post: 03-02-2009, 11:34 PM
  4. How to wire an 8 wire stepper motor
    By technosteve in forum DIY CNC Router Table Machines
    Last Post: 01-17-2009, 12:01 AM
