586,728 active members*
2,572 visitors online*
IndustryArena Forum > CAM Software > Mastercam > Mazak with 100% X2
Results 1 to 8 of 8
    Oct 2008
    45
    Mazak with 100% X2
    Hello All,
    I was wondering if anyone would mind pointing me in the correct direction about what would be a good starting point to build a mazak post. I am not asking for a post but just a good starting point to config one. But if you toss one to me i wont say no lol.
    I am running X2
    Thanks everyone,
    Inky
    Apr 2003
    3578
    HERE IS A GOOD PLACE TO START.
    http://www.emastercam.com/posts/
    Download the MPmaster post.
    Cadcam
    Software and hardware sales, contract Programming and Consultant , Cad-Cam Instructor .
    Oct 2008
    45
    Thanks Cadcam!
    I will start working on it today.
    Inky
    May 2007
    71
    thanks
    Jun 2009
    11
    Thanks cadcam
    Very helpful Info !
    Tony
    Oct 2008
    45
    Ok new question!! Does anyone know if a EIA program will allow tool changes in one program. Rather then a bunch of sub programs for each tool.
    Just a example of 2 tools running in a mazak would be fine with me.
    Jun 2009
    11
    Hi Inkydo69
    Yes you can have multiple tool changes in 1 program ...in mastercam X2 if you are getting a sub for each tool .....Try this......before posting RIGHT click in the operations manager on the white area select Edit Operations then select Change NC file name ......it will post all tools in 1 file .......it is ok if you name it the same as it was just as long as you go thru these steps ...Then post the file
    Tony
    Oct 2008
    45
    Final
    Quote Originally Posted by TonyAllen View Post
    Hi Inkydo69
    Tony
    Thanks for the info!
    Now I have found i don't have to sub a G code program in a mazatrol i can just use full EIA to run a mazak. I am sure i didn't explain what i was getting at. Now i know what to do thanks to everyones help here and in the mazak thread.
    inky
  1. Mazak QT-10 T2 manuals --acct w/ mazak?
    By CDTINC in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 09-21-2012, 05:09 AM
  2. Mazak
    By mprotic in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 08-10-2007, 12:06 AM
  3. Mazak QT-200,Mazak VTC-160A,Mazak FJV-250 all pcb problem
    By sting_dot in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 05-22-2007, 02:20 AM
  4. Mazak
    By jackson in forum MetalWork Discussion
    Last Post: 03-22-2007, 04:06 AM
  5. mazak qt-8
    By theguild in forum Uncategorised MetalWorking Machines
    Last Post: 03-03-2007, 12:22 AM
