586,082 active members*
3,807 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > error 1001 (EMERGENCY STOP SWITCH ON) in Fanuc series oi-MC
Results 1 to 2 of 2
    Jan 2018
    11
    I have error 1001 (EMERGENCY STOP SWITCH ON) in Fanuc series oi-MC Controller.
    This error came from input X8.7 which is always read as zero in the controller but it is on in the I/O Board.
    I checked the cables, the I/O Board and the I/O modules but all seems OK.
    I also noticed that the controller can't see some inputs X.
    Could it be a parameter problem, cause I tried some parameters from other machines (same model).
    Please help, thanks.
    Dec 2009
    953
    Re: error 1001 (EMERGENCY STOP SWITCH ON) in Fanuc series oi-MC
    i had the same error not long time
    the easy fix is quite easy,you do not know how much i spent finding it and was a luck to find it because is not related to anything as you think.
    open the operator panel and you will find Distibuted I/O card with 3 fanuc cables and the problem comes from the middle one that is loosing contact.
    i opened the cover and make some electric band on it untill new cable arrived.
    now machine works over 2 month with new cable.
    check the photos.
  1. Error 1001 in Fanuc series oi-MC
    By MSAAA in forum Fanuc
    Last Post: 08-26-2019, 03:00 PM
  2. emergency stop switch error
    By reedmiles in forum Haas Mills
    Last Post: 03-25-2017, 08:51 PM
  3. need help to connect the limit switch and emergency stop in Mach3
    By ali hedi in forum CNC Machine Related Electronics
    Last Post: 04-07-2010, 11:11 PM
  4. Emergency Stop Switch
    By BOBINETTE in forum Hobbycnc (Products)
    Last Post: 12-28-2007, 06:41 AM
